Results 1 to 2 of 2
Thread: Oil Level
    Calgary, AB. Canada
    Question Oil Level
    Checked the oil today prior to a 600 mile drive and found that it was up to the stop on the dip stick. I've had no power loss while towing or smoking. Mr. Hook has towed it to the Dealer. They tell me it is probably injectors, (2003, 3500, 57,000km.).
    My question is how would the fuel get into the pan ???
    Will they replace them all or only the offending ones ???
    Man I can't believe my luck in checking the oil, I'm out to buy Lotto right now.
    2003 GMC 3500HD D/A, EC/LB, 4x4
    Injector body defects or loose/defective fuel return lines.
    GM should replace all eight.... Check the Injector Warranty page for more info.
