Results 1 to 20 of 39
Thread: Duramax Diesel Conversions
    The brake fluid level indicator sensor is a normally open circuit, closed when the fluid level is sufficient. You should be able to shunt the connector to get the lamp to go out. If you do this and the lamp stays on, then you have another sensor or switch in the system that's not happy, or missing, or the brake fluid level harness is not wired correctly into the system. The EBCM (Electronic Brake Control Module) receives the input from the brake fluid level switch, and controls the IP lamp. If you pacify all the switches/sensors, and still have the lamp on, I'd suspect an issue with the EBCM, or a weak/missing ground in the circuit. If you haven't installed the late model EBCM, that could very well be the problem, with the BCM missing the input, or the input is not correct from the park brake switch (which is monitored by the BCM)
    When beginning a project as complex as a Duramax conversion, it's helpful as you work through the project to use checklists, and then concentrate on one or just a few steps at a time. A person can become bogged-down and discouraged when contemplating the entirety of the project. Again, just concentrating on a few steps at a time helps to keep you focused, and allows you to see and measure progress in real terms.
    When our project was in the planning stages, and while actually working through the conversion, I created many lists that I used to help keep me focused. Here's one of those lists (yes, I kept them all).
    When taken as bite-size chunks, the project becomes doable for most people. A list helps keep you focused....
    May 2005
    SE Wisconsin
    This is excellent advice. I have done this and it makes me more focused and also helps me plan ahead so I have the parts I need when I have the time to do the work.
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
