i cant seem to get it started now that its in my one ton
finally got it runnin but its kinda rigged.i still need to find the power steering brackets.
are one and two peice rear mains the same as far as the flywheel
mark
The clutch disc used with the dual-mass diesel flywheel does not have any internal springs or dampers. The clutch disc used with the newer single-mass diesel flywheel incorporates a series of springs/dampers.
So.... you have to be sure what flywheel you have before ordering/installing a replacement clutch disc.
The same flywheel/flexplate can be used on either rear main seal engine.are one and two peice rear mains the same as far as the flywheel
mark
