G's conversion
No updates other than I'm in the middle of the A/C season in FL-fortunately a HOT summer FINALLY!
It does run & drive, I'm in the laborous(?) process of IDing all of the 99 inside harness connectors then "breeding" them to the correct wire in the 01 harness--so when the a/c fuse blows(01 panel)it's actually the a/c that blew it!, etc., etc.
Oh, we didn't mention.....I had a donor truck-01 K2500HD; I'm using all of the harnesses.....mine is a 99 L65 C2500 Sub.
No, there are NO clearence issues...actually, it is about as tight as the 6.5L was.
I'm not a big forum user(cause between this & the 409 stuff I wouldn't get anything done on the truck if I was), so if you have ?'s, post & I'll try to be better about reading. If you're in a hurry, email me @ gordon@marksair.com.
This is NOT a conversion for the "lighthearted"!
G
99 Sub L65<BR>IC,3.5\" Kennedy Exh.& boost cont.,TT PCM, FSD cooler(didn\'t help),rr bar,Isspro gages,B&M trans control
Gordon Marks
