Results 1 to 20 of 100
Thread: Detroit Diesel
    Nov 2007
    Third Coast
    Lightbulb 4-53 Conversion
    They are only expensive if you are going to pay a shop to do it.... You can get a complete rebuild kit for a 4-53 for about $1200.
    One cool thing about the 2 cycle DD is they dont have a central high pressure and high price injector pump just a continuous loop fuel pump and the injectors are mechanical... rocker activated plungers... you can loose an injector or two and they just keep running! The 2 stroke DD date back to WW II developed for the armed forces as a simple and reliable engine.
    You can also thumb your nose at the Oil Barrons! How? In warm climates you can run the Detroit Diesel On well filtered waste fryer oil or in cooler climates Preheat WVO & Block.... Google treehugger they ran a 2-71 generator on strait WVO for 40,000 Hrs (if my memory serves me) then donated it to a NY Museum were it's still chugging away!
    FREE FUEL!!!
    None of us are as smart as all of us.
    Apr 2007
    Alberta, Canada
    its hard to not want such a great sounding engine with a strong history of reliability. if my memory is correct, the 71 series was produced for about 60years before it was discontinued.
    there are a few videos on youtube of a 1964 chev 1/2 ton 4x4 with a 3-53 from a gama goat in it. he claims 28 mpg on the highway. pretty good for a full size 4x4. and it sounds pretty damn nice
    i definately want to get a detroit diesel into a pickup truck one day, but most people around here are very discouraging and always say "an easier and better engine to swap in would be a cummins"......i don't want a cummins though
    but if i can find a good engine, running or else in need of rebuild then i think my project will be under way.
    2011 VW Jetta TDI, pretty well loaded without leather.
    2006 GMC Sierra D-max, 4x4, 4 door, bumper, winch, Espar heater, and the HID lights are a nice touch too.....
    1986 GMC 3500, 454 on propane, 4 speed, 4x4, crew cab dually......the welding truck
    1984 Toyota 4x4 pickup, 4.3 V6, 700R4, Toyota t-case.......transforming into 4x4 cage buggy
    Jan 2005
    Kazan
    I had a 4-53 in an IH travelall. Things I disliked: Noise (but that is exactly what you LIKED), fuel economy (only got 12-13 mpg). Things I liked: Power and torque.
    My boss had a 4-71 in an old work truck and it always sounded a lot more "sedate" than mine (lower rumble, smoother), not sure why.
    If you want to go with the aluminum 4-71, I would recommend investing in an Allison 1000 transmission (if you want A/T) or one of the newer 6 or even 7 speed manuals. The DDAD's rev like there's no tomorrow, but they don't like to lug. Right gears will make the whole experience a LOT better.
    Apr 2007
    Alberta, Canada
    well if i were to do this, i'm thinking of a pickup truck size here, and 4x4 as well. but preferably manual transmission. just seems to me that a 4-71 is a bit taller and heavier, and a 6 or 7 speed for it would be a fairly heavy transmission as well. would make me worry about the front axle a little.
    my dad still has a 1969 gmc 9500 tandem axle truck on the farm. he uses it every spring and fall and it doesn't seem to let him down. its got a 6-71 that has been rebuilt twice, the second time was due to a broken crankshaft from the first rebuild which was only about 100 miles old at the point of the second rebuild. but even if those engines don't usually like low rpm, this thing could tear its own brakes apart in low gear............
    i grew up on the farm and listening to that truck throughout the years made me love the detroit diesel sound. which is why i am wanting one in a pickup truck now
    Apr 2007
    Whitmore Lake,Mi
    Default 4-71 Detroit
    To bad your so far away. I have a 4-71 but it has a cast iron block. all the parts are there needs an overhaul tho...........even have an inline bell housing that's aluminum for an automotive application
    Question
    Do you know if the 453 and 353 have the same bell housing pattern...hate to sound stupid. Am I wrong thinking the 353 is a DOT 3 and the 453 is a DOT 4? I keep coming up with conflicting info when I search the web. Will a particular Chevy bell housing bolt right up or is there a lot of modifying involved?
    Apr 2007
    Alberta, Canada
    Quote Originally Posted by tjmac77 View Post
    sorry, not sure exactly. i myself am still wondering whats required to make a chevy transmission bolt up. the guys at the local detroit dealer told me that they use SAE #1 bellhousings on the motors. and he never specified what size or series though....
    Apr 2007
    Whitmore Lake,Mi
    Thumbs up Rear housings
    the inline rear housings will interchange, I think there are 3 maybe 4 different different size openings for the flywheel and clutch assembelies. they also have adapters to fit different applications to power transmissions PTO's or hydraulic pumps. WHEN you start getting down to the nitty gritty of putting this thing together I can fax you a sheet with the spec's and measurements........have to dig it out of the archives
    Dec 2004
    Georgia
    Quote Originally Posted by journeyman View Post
    I worked at a Detroit Diesel/Allison shop for years. The rotors inside the blower are shaped differently on a 53 series than the other series Detroits (71, 92, etc). The 53 rotors are straight while the 71 are twisted into a spiral shape. That's why a 53 series is louder than a 71, the extra noise from a 53 is coming from the blower.
    Apr 2007
    Alberta, Canada
    I am now on the hunt for an aluminum block Detroit Diesel. In fact, an engine with aluminum heads and front/rear covers would be ideal.
    6V-53 preferrable, but I am also considering a 4-53.
    Obviously, I'm willing to pay shipping costs to get it here, so then naturally aluminum would be nicer for that as well.
    Running or not, if its an aluminum block I would like to get my hands on it.
    Thanks.
    Nov 2006
    Since we're on the subject of aluminum Detroits, here's a pic of my aluminum 4-71 in my 1 ton Silverado.
    A lot has been done to the motor (ceramic coated piston domes and teflon coated skirts), Jet-hot coated exhaust (and turbo), etc. It will also be intercooled. I have a 10 speed Roadranger to go behind it.
    Nov 2007
    Third Coast
    Angry update
    Quote Originally Posted by reighna View Post
    FREE FUEL!!!
    Google Green-trust to find web site, 4,000 hrs is correct, $600 for 4-53 kit...
    Jan 2008
    Maryland
    Default 4-53 performance info
    I am new to this forum. I am looking for any information on getting maximun HP out of a Detroit 4-53 engine. The engine is in a pulling tractor and currently turning it 3200 RPM with 100 inectors. Wondering if can do head work, camshaft work, etc. to increase HP? I can't run a turbo. Any information will be appreciated.
