Results 1 to 10 of 10
Thread: 6.2 conversion checklist
    Jan 2015
    Oregon, USA
    Default 6.2 conversion checklist
    Is there. General checklist for a diesel conversion? After a lot of time debating the subject I decided I'm going to convert my 1965 C20 to a 6.2 gm Diesel engine. I currently have a SM420 4 speed so that is not an issue (plus local highways are only 55MPH anyways, so who cares?). Obviously I will be replacing the gas tank (and relocating it to the rear). At this point I've found some 6.2's on craigslist from $250-$750 ($750 had a turbo) so the cost seems fairly low to me. I would prefer to keep everything possible mechanical as there's not a computer on this truck anyways. I've found a nice one for $500 or make an offer on what's left of the truck, though in thinking about waiting until I find one that's all there, just beat up or cosmetically in poor condition, I feel like this would save some headaches.
    So what is the simplest way of going about this? The wiring on the truck can't reall get any more straight forward, what does this engine truly require to be bolted up to a SM420 then started? I have very limited diesel experience on passenger vehicles, and more experience on heavy equipment, so I'm not really sure where that places me.
    Pretty straightforward. The 6.2s and early 6.5s were mechanical. It wasn’t until later 6.5s that they were computer controlled. Bellhousing configuration and bolt patterns and motor mount configuration are the same gas to diesel. You’ll need the diesel accessories including starter and larger radiator.
    6.2s were mechanical lift pumps, so I’m thinking you’re basically talking wiring the starter, glow plugs, fuel shutoff, and charging system.
    Best situation is always to buy a donor vehicle so that you have everything you need. If you just buy the block, you’ll likely end up nickel and diming yourself getting all the little things you need.
    Diesel Page Member #2423
    Jan 2015
    Oregon, USA
    Awesome, thanks! I'll probab wait and look for an old farm truck or a a wrecked truck then, I'm in no hurry. I have a running 250 I6 hooked up right now.
    It's more simple, and less simple, than just that.
    Fitment-wise, what you want to do is probably the simplest conversion. Everything will fit, and mounting parts will be universal. Electrical is also very simple. The current Ign. circuit is all that's needed to power the injection pump. The HPCA and high idle (to coolant temp switch) will tee from that lead. The starting/charging circuits will be the same as original, with the simple change to an internal voltage regulator. The starter, obviously, is different, but connects the same. You'll need to add another battery tray, or accommodate a much larger single battery. The glow plugs can be either original, with the engine-mounted controller system, or manually switched (or both). These are all simple accommodations, and should be cheap or free, depending on what you get with the engine, or chassis you buy. I don't think you need a whole truck, as you'll be re-plumbing the fuel lines, anyway. You'll need to add a fuel return line from the engine to the tank. If you are relocating the tank to the rear/center (spare tire space), you can use a late model Suburban or Blazer tank and sender (meaning, if you buy a donor vehicle, a Burb/Blazer/Jimmy would be best).
    Where I think you'll have a problem is the tranny. Your current 420 won't hold up to the Diesel, especially if there's a turbo in your future. That is, if you can even source a clutch/plate that will match. An SM465 would be a much better choice.
    Good luck! This should be a fun project.
    Dec 2006
    North Pole, Alaska
    The 420 trans will work fine. It's not much weaker than the 465 and a 6.2 goes nowhere close to the max power it can handle.
    Jan 2015
    Oregon, USA
    Awesome, thanks! I'm not planning a turbo (no point if I keep a 4 speed, if I go and swap out the tranny I may as well do the 4x4 conversion while while I'm at it. for now I just want a good clean running work truck for puttzing around and short cruises (we have a 55 mph speed limit on the highways here). I know people hook up 4bt diesels to the sm420 all the time so I figured since I'm not hot rodding it or anything it would be okay. I'll figure it out when I have the cash and parts accumulated. Thank you again!
    Quote Originally Posted by AKMark View Post
    Cool, I figured a N/A 6.2 wouldn't be a huge deal, long term I either was a short bed stepside that I'll put a good solid tranny in and a turbo diesel or I'll just keep upgrading this. I used to not want a long bed, but I've fallen in love with mine.
