Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: If you were this far would you pull the engine? Is it worth the trouble?
    Nov 2006
    pa
    Default If you were this far would you pull the engine? Is it worth the trouble?
    As most of you guys know where I am at one my engine. I am down to the timing set and rockers assemblies out. I do see some rocker and push rod wear.
    We already know the problems with the engines(blocks cracks,cranks break,ect..ect...)
    I have 170,000 on my engine and it is 4x4. I know how to pull engines and rebuild them. I worked on engines for about 16 yrs. I am just wondering if you were in my shoes would you pull the engine and check eveything out. I do not know what the bottom look like and I am not worried about pulling it. I just don't know if it is woth it. Also I am not sure what I will find and be happy. Then you get into what to do once you get it out. bearing,rings...ect..ect.
    So I was wondering for you long time 6.5 guys (mechanics) or anyone else what would you do????
    I never thought I was ever going to go in this direction but lets see what you think...
    Thanks guys for all your time and posts back to me. If it was not for this forum I would still be fighting with the pmd.
    Thanks again Joe
    95 suburban 2500 4x4
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    http://home.dejazzd.com/jkauto/6.5%20PARTS%20PAGE.htm
    MY SUBURBAN INFO HERE
    Drop the pan (not too bad on a 4x4) and check for cracks. If everything looks good, slap in a new oil pump and seal it up. If you have a 2-piece rear seal, could be a good time to refresh it. Use a later model high volume pump if you think you should. Hung jury on that one.
    If you had good compression, I see no reason to pull the engine. It's very likely you'd just be replacing the same parts. If you have doubts, Plastigage the bearings (rarely any problem there). If you aren't pulling the heads, I wouldn't sweat it. If you need to replace the lifters, it can be done with heads on (enginuity and patients may be required).
    Nov 2006
    pa
    Well I have a small coolant leak and I don't know where it is. I am probably going to pull the heads and use better head bolts. rear main was replaced 20 miles ago. long story but trans just got rebuilt. Yes I need to do A compression test today and see what the outcome is.
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    If you are already pulling heads, it's a toss-up. I've done them in and out, and it's just about a wash, comparing convience, time and busted knuckles.
    There is only one "type" of head bolts. Fel-Pro is the preferred brand, but I'm not aware of a "bad" brand. They cannot be reused, they are TTY (torque to yield). The only other option is studs, and an in-frame R&R is not fun with them (pull the engine), but is possible. No advantage to studs with stock to moderate bombing, but wouldn't hurt, either.
    Nov 2006
    pa
    No I did not pull the heads yet. If I am right you need the
    1. front diff dropped
    2. engine cover
    3. exhaust crossover
    to drop the pan
    1. all the above
    2. oil cooler lines
    3. bell housing bolts
    4. engine mount bolts
    5. starter
    5. wires ect..
    to pull the engine...
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    Pretty much, but you don't need to drop the diff to pull the engine. Also, you'll want to pull the hood, radiator, or ideally, the full front clip. The front clip doesn't take long, then you don't have to mess with clearance or chance damaging the stack with wrenches, accessories or the fan. It also gives you a chance to get the radiator refreshed and renew aged wiring, and paint, etc. There are a number of ways to do it. Time, experience and resources usually determine the route. It's also best to evac. the A/C, so you don't have to mess with that. Just get it out of the way, first.
    Nov 2006
    pa
    right I understand. I am tring to keep this as long as possible. I think I am going to
    1. commpression test
    2. drop pan
    3. take heads off
    4. check everything out.
    5. slowly put it back together using updated stuff like arp studs and gm tablets (seal coolant)
    I think this shounds like a good plan?
    I have everything down to the timing chain. rad it pulled. turbo is out. intake gone. fan gone. intake gone. fuel filter gone.
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    Yank it out yank it out.
    The engine is so much easier to work on and to see what you need to see while on a stand.
    There are several things that will need work at the miles on the clock you have.
    Soft plugs will almost certainly be near rotted though.
    I have not seen any high milers that were not.
    Yank it all apart and be sure and steel stamp the rods on the pan rail side on the part line as GM does not do this.
    A minimum you can steam the thing down good and then see what you have.
    A small coolant leak is most likely #2 or #7 cylinder head gasket thats about to die a violent death. I say this from experience, been there done that.
    You can also assess the condition of the heads the block, crank, cam ect.
    If all is ok a valve grind along with a light hone on the cylinders and some fresh rings and bearings and a few gaskets and seals and a rattle can of black paint and your off to the rodeo.
    I did this very thing a year ago on our 94 Burb.
    Its far easier to work on these little cretures out of the truck.
    You can really get a good look at the main webs with loads of daylight after a good steam cleaning.
    At home the easiest way to check for cracks is to use a propane torch and warm the web areas at the outer bolt holes on both sides until hot.
    Any cracks will bubble oil really good if they are present.
    The cracks many times are not visible to the eye even when the sucker is clean without doing this.
    Have the crank magged and probaly a nice pollish is all it will need.
    While you are there you can look the cam over well too. be sure to bag them lifters up and mark them though.
    Most of these engines will be fine with just a new timing chain as the sprockets dont wear much.
    Watch ebay and bearings and rings can be found real right if you know prices and such.
    These engines use select fit bearings on both rods and mains.
    I have seen Std Std and also unders std and so on but never mismatched between rods.
    The rods will usually all the be the same size and so will the mains.
    The numbers will be on the inserts if they are still from Ma General
    This is all metric sizing. the numbers will be followed by US
    You can also find the upper and lower shells on the same throw a different size.
    If they are all close to STD use STD bearings.
    Mine had some .0005 (in inches) under rods but I used STDs as the select fit stuff is only available from the MA General and they are spendy.
    Clevite 77 is a good choice on bearings.
    OH BTW when I yanked the 94 down the only thing I removed was the hood I blocked the radiator with some plywood.
    The engine will come out very easy.
    I used my BOBCAT and hung an air chain hoist and did the whole removal myself. (Except removal of the hood)
    Easy job from where you are now. Get rid of the exhaust manifolds before you pull and then replace them after the fresh one is back in.
    There is plenty of room otherwise.
    The only nasty is getting the two upper bell housing bolts out as the fuel lines run up to a bracket that is attached with stud tops and lock nuts there.
    Good luck and let us know.
    Robyn
    Nov 2006
    pa
    Unhappy Compression test done... pics and video
    Ok here are the results of this test Going from drivers side front to back then to pass side front to back
    df pf
    450 420
    440 450
    460 480
    380 440
    I got what I believe is blow by. check the vids on that. Also I have oil in the pass side 3rd one back check the pics
    I am not sure why the oil is in the cylinder and filling it up also I do not know why the one is lower then the rest.. This really sucks. I just wish it was better but it is not.
    here is the links
    pics
    http://www.putfile.com/j_k_auto/images/124193
    video
    http://www.putfile.com/j_k_auto/media
    They are the first 6
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    Nov 2006
    Raleigh, NC
    I think all 6.5TD's in PA have horrible blowby...
    I'm in the same boat as you, only I'm gonna start with a fresh block...that and I'm curious just how much dino oil I can burn with my engine until it says it's had enough...
    Good luck with the project!
    Eric
    '95 Tahoe 6.5TD
    Current:
    3" Turbo back - 14 bolt SF - Vin F intake manifold - typical guage pod setup - Turbomaster - Free blowby mod courtesy of GM's 22:1 + boost
    Coming:
    Cummins IC - new turbo elbow w/ 3.5" DP - 4" Intake - new block w/ 18:1 slugs
    #2 and #7 are the low ones. My bet says #7 is leaking water and this may also be why the compression is low.
    Get the little beast out and do a post mortem on it and go from there.
    All is not lost. As long as your block and crank are good your set.
    The pistons and rods generally fair well in these too.
    Look for the normal stuff such as scuffing and so on.
    The piston crowns in these have a hard Black coating on them to help reject heat. Inspect them carefully in the area around the Recardo Bowl for any sign of cracks.
    The valve seals are not all the great in these engines and when they fail you can get a fair amount of oil seep down the valve guides.
    If the cylinder has a minimal ridge at the top probably a hone and re-ring is all it will need.
    Your compression on all but 2 & 7 are fine. The 380 is the one that runs up the red flag.
    The head gaskets at the 2-7 locations are notorious for failing. The gasket soft material goes away over time from the coolant presence and then the fire ring will corrode and poof its over.
    As long as there is no nasty etching into the block from the fire ring you wont have to deck the block.
    Felpro makes a .010" thicker gasket to allow for a deck job.
    Robyn
    Dec 2006
    Lancaster, PA
    Watched some of your videos Joe.
    The turbo fan slop isn't an issue - yet - but I'd keep my eye on it. Mine's about the same and doesn't make any noise.
    However the play in the wastegate doesn't look too good.
    Regarding blow-by. GMCTD had posted the following in a thread some time back in response to a CDR question I had:
    Then, engine idling at op temp, pull the dipstick
    Place a 36" length of 3/8" clear vinyl tubing over the dipstick tube
    Place the open end in a container of water
    Keep it much lower than the dipstick tube - prevents water in the crankcase
    At 2000rpm, the water should rise in the tube about 1-2"
    The higher the water level in the tube, the more restrictive the air filter - dirty, wet, etc.
    Bubbles in the water means excess blow-by
    If it blows all the water outta the container, ya gots really big problems.
    But, the test should give you some indication of how much oil to expect thru the CDR
    PM or email me if we can set my timing Friday evening.
    Thanks,
    -Bill
    95 K2500 6.5TD, Ext cab, short bed, 123K, FSD Remote, minor overhaul @ 123K: new injectors, glow plugs, glow plug relay, injection lines, heads, exhaust manifolds, harmonic damper & idler damper, water pump, (timing chain at 3/8" play) 4" exhaust, K&N air filter, CDR valve, trans cooler lines, alternator. Dead Kitty & deactivated EGR. (MPG: 11.5 before work listed, 13.5 afterwards & 17 w/ Marvel Mystery Oil)
    Nov 2006
    pa
    thanks for the post. I was wondering if the oil in the cylinder would bother you? It is just laying in there.
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    Nov 2006
    pa
    Quote Originally Posted by billschall
    that is why I replaced my turbo with a gm8. The videos were to show everyone so I could figure out what I wanted to do. Atleast it is updated now
    Also I do know about this test but I do not have my engine running to check that blowby. Never expected to go in the wrong direction with the truck but since I got it a year ago it't been fighting me...
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    Dec 2006
    Lancaster, PA
    Quote Originally Posted by j_k_auto
    yep. if it were me, I pull the heads first & get 'em tanked/magged, etc... If the machine shop gives the heads a thumbs up, then yank the block.
    Saw your compression videos after my last post then realized that the blow-by test would be rather difficult at this stage. <duh>
    That li'l puff of smoke coming out of #6 (the oily one, I believe) thru the intake port doesn't look to promising.
    Bummer, dude. I feel yer pain...
    Nov 2006
    pa
    Angry
    well I am probably going to yank it and go from there. I figured I would atleast got a couple of years out of this engine but my luck just stinks. Oh I bet if I go through with this I will find the heads and block are junk . Even though the heads are only 3 yrs young.
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    Not to dispare
    If the rig is in otherwise nice shape its well worth fixing the engine.
    A new Burb will tear up $50K to buy and to my knowledge a diesel is not in the offing.
    There is every reason to be optimistic about the foundation.
    Our 94 had 230K on it when we bought it off of ebay in Feb 05 and it had 238K when the engine finally said enough.
    Fresh set of clearwater heads, rings, bearings and sundry other little goodies and a couple months down and it was good as new again.
    Block was near perfect with no cracks and so little wear in the cylinders that there was no reason to bore it.
    The heads were used up though.
    New injectors and I rebuilt the turbo with a bearing and seal kit just for drill and this thing runs as good if not better than new.
    Just dig in your heels and go at it like you's a killin snakes
    The total cost for parts and some limited machine shop (tank and Mag) was under $2K
    I see that rig remaining in our stable for some time as it is worth more as a spare driver now than it would sell for.
    Go for it and keep us posted all the way..
    We'll be here if you need advice along the way for sure.
    Robyn
    Nov 2001
    Aitkin, MN
    Good Day!
    Upside potential: If they don't pave the roads where you live with salt in the winter, it might be worth running 'er over to Ziebart & get it rustproofed, it's pretty reasonable. Then get it insured for high value - lots of insurance companies will gladly do this & at not that much of a premium, they just want pics on file. That will protect your investment. There's no reason a fresh motor shouldn't put 'er back on the road for 10 more years.
    Blessings!
    Nov 2006
    pa
    Well I think I know how I got oil around the piston. I put my turbo return line in a can and it just started to over flow. I quickly wiped it up but some must of went down the intake. At least that is solved.
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    Dec 2002
    Long Island, N.Y.
    Dr Lee suggested to (regarding block cracks) :
    just wipe down the bearing-web inner block areas to clean them up good ...
    then take like a coffee break , and when you come back , the oil should have visibly emerged from any cracks.
    In most cases the lower end bearings are OK, and the cranks are fine if the dampener is maintained.
    John Kennedy suggests removal of engine when replacing heads just to enable resurfacing the firedeck (upper mating surface of block tends to be eroded/corroded where headgasket compresses ring onto castiron block surface).
    Robyn has had good luck with head rebuilds . I think the heads , at $500/ea from peninsular , are cheap enough to be considered disposable. I also think they are by design disposed to cracking , by virtue of the induction-hardened seats. And the new OEM heads have larger coolant passages....
    I removed some block "freeze-out" plugs , and found them to be absolutely free of any corrosion on my '95 with 175K Mi -- the aluminum radiator also had NO indications of any corrosion at all ... courtesy of the pink coolant.
    I would not worry about the compression [the one cylinder IS a bit low] , but if you have the time to go over it , it would be nice to pull the rod bearings , and measure bore wear. Six of my bores were worn .002 oversize , the other two were worn .007" oversize. I think one of my pistons has a little slap , esp at certain temps.
    IFF you establish No obvious block cracks , then you really know something useful...
    My feeling is replacing the headgaskets is good insurance , but it is a job , too.
    tom m
    '95 6.5td 4L80E 3500/srw p/u
