Just wondering what the largest tires are that I can run on a dually setup. I would like 33's with a four inch lift. Is this possible?
You could do it with some 245/70R/19.5s, about $300.00/tire.
1997 GMC Savana - 6.5 TD
1967 Jeepster - Stock
1986 Jeep CJ7 - Stock
255/85/16. 33" tall and about 10" wide. You can typically get those onto the rear of a dually with no problems. Anything wider and the tires can rub on each other.
