Results 1 to 10 of 10
Thread: 1991 Ranger gas to DIESEL swap
    Jul 2007
    Cincinnati OH
    Default 1991 Ranger gas to DIESEL swap
    Anybody know of anyone who has made the gas to diesel switch in a Ford Ranger P/U?
    I have a 4x4 Supercab 5 speed Mitsubitshi trans, behind a 2.9 Ltr gas engine.
    Body and interior are perfect, frame has light rust.
    I do not care if it remains a 4x4 after the conversion. (anotherwards to get a diesel to work, a total removal of engine, tranny, and transfer case, whatever it takes).
    I read where one guy suggested a GM 6.2 ltr might. Would not that be TOO big to fit in the engine compartment, not to mention the weight?
    I am not out for performace, big towing power, my goal is mostly fuel economy.
    ANY suggestions, ideas, etc would be appreciated.
    THANKS!
    Hi
    The 6.2 is a large heavy motor,anything is posible if you like a chalange and have good mechanical skills.
    I did see a ranger once with a factory diesel motor,probly scarce as hens teeth.
    If you are using this just as a comuter i would look for a smaller motor,less work to shoehorn in and probly get better econamy.
    Good luck,and keep us posted
    Thomas
    May 2005
    SE Wisconsin
    Probably better off using a VW diesel. I think there are adapters made for that at ACME .
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
    Sep 2003
    Feeniks, Aridzona
    I would probably stay away from a 6.2/6.5 for that. There are a lot of 4 cyl diesels that I think would work better in that. The VW diesel might be a little small. I would look for something in the 3.0L to 4.0L size for that.
    Jun 2006
    St. Albans, WV
    I think the VW TDI would be a good choice, especially with a chip and set of performance injectors. It would make more torque then the stock 2.9L Ford powerplant and still get great fuel economy (in comparison).
    Default conversions
    first you need to figure out how much hp you need and the fuel economy you desire as far as transmissions there are plenty of options you dont need to keep the original ford one dont be afaraid to think outside of the box this place has adptor kits for sae bell housings http://www.phxgrp.com/transmission.htm
    here is a site that has lots of motors
    http://www.dieselenginemotor.com/
    the ones that kim w has he is real helpfull with the motors I just purchased one that i am going to put in a s10
    Jan 2005
    Kazan
    Keeping your facotry transmission/xfer case will greatly simplify the conversion. If you can buy an adapter plate/clutch set up, you might be surprised at how many issues 'go away'.
    Aug 2006
    WV
    429s have been shoehorned into rangers
    Shane
    Quote Originally Posted by journeyman View Post
    Except for the problem of a 4-cyl tranny continuing to "live" long behind a diesel...
    Feb 2006
    Point Pleasant, New Jersey
    Put in a 3.9 cummins
    Kris
    kris985118@comcast.net
    1982 Chevy K10 6.5TD shortbed stepside 700R4, 5inch pipe
    2003 Dodge 3500 4x4 cc/lb Cummins HO/48RE, K&N kit, straight pipe, roktech, FASS, six-gun/sl with PDA boost,pryo,trans,fuel gauges
