The perfect gear ratio for stock sized tires (235/75 R15's) is 3.42, good fuel economy.
For pulling 5k regularly, I'd suggest 3.73 gears, which will still grant decent fuel economy running empty.
2.73's really won't allow you to pull a stump out of the ground, or 5k at highway speeds with a tail wind
GM geared a LOT of these 6.2's will TALL gears, mainly cause the target was maximum fuel economy, later on, they wouldn't pull well and the owner usually suspected the poor diesel engine under the hood. It's the gears.
J
P.S. Welcome to TDP's forums!
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
