Quote Originally Posted by gmctd View Post
Certainly a lot more comfortable, also - what's the configuration, 4L80E output to drive axle.
Is this the one you were agonizing over replacement 6.2, 6.5 upgrade, and we were suggesting IH or Cummins - or was that another member, here?
How's the power vs thermal dissipation with the engine at the rear?
I wasn't agonizing over engine replacement (although I would have been had AMG not bought the 6.5L TD from GM). A Peninsular Diesel engine (done to my specs) has been a worthwhile investment.
Thermal dissipation is excellent, but one should know that the radiator on my diesel pusher has about 3X the capacity of the typical front-engine setup - and the oil cooler and A/C condenser have their own sites. Only the transmission (a 4L80E [HD aftermarket] as you mentioned) has a passage in the radiator. The radiator fan dwarfs those in pickups.
Drive axle is a Dana 80, but I don't know the ratio. It, and the tranny, have Mag Hy-Tech pans/covers.
