Results 1 to 11 of 11
Thread: The ride that gmctd built
    Sep 2000
    usa
    Default The ride that gmctd built
    I joined the 'Page back in ought zero as a direct result of building this truck, seeking 6.5 camaraderie, offering relief from all the 6.5 myths, old wive's tales and snake oil, while looking for any reliable performance upgrades - and still crazy, after all those fears
    jd
    NutNbutGMC Guest
    Nice looking machine. I like it.
    Thanks for sharing...
    So tell me O-Fair-Truck-Making man.... which shall it be? The Dodge or the GMC....???? What's yEr favorite of the two that you drive?
    Sep 2000
    usa
    Thanks for your interest - I had a good time building it, and the GMC gets lots of attention, particularly from 18-wheeler drivers when I'm on the road with the twin-truckers cb antennas affixed thereunto, but...........
    I also had a good time building the Dodge, and I've always liked the sound of a big six, long since I was a teenager with a Chevy 3-window with the big 272-292cuin six from a GMC dumptruck - six in a row makes it go, you know..........
    So - in all honesty, I'd have to say.........yes, to your question as to which is my favorite
    jd
    Apr 2007
    Tigard, Oregon
    JD, that is one clean lookin' Jimmy!
    The dual antennas are the finishing touch, -without a doubt!
    Nice classy lookin' rig for sure.
    Rich.
    1994 K2500, 6.5, NV-4500, 4.10's, T-Master, GM4 at 18, Cranked DB2 at 5 BTDC, 599 block .020" over, decked .010", ARP studs, 18:1 Mahle marine pistons, SCAT 9000 steel crank, HV oil pump. Dual-stat/130GPM, C2 boost/pyro, 3"x4" Exh, ATA I/C in process.
    NO MORE DS4, NO MORE PMD'S! I RELOCATED MY PMD TO THE TRASHCAN!
    May 2007
    Pennsylvania
    Just imagine the view from the sub-compact car drivers' rearview.
    ...Clean up in isle 1...
    Very nice looking truck.
    1998 K1500 Silverado Ext Cab SB 6.5TD L56 4L80E 342 locking rear - 60k miles
    Modifications: Ported and ceramic coated exhaust manifolds, worked GM-8 turbo, L65 upper and lower intake, marine injectors, boost, EGT, and Trans Temp gauges, SSDiesel air intake, Hearthrob/SSDiesel stainless 3in down pipe, 4in exhaust, and 2.25 crossover.
    Planned: Remapped ECU, intercooler, turbomaster, fluidamper, fan/clutch upgrade, upgraded oil cooler and lines, and lift.
    Apr 2007
    Tigard, Oregon
    Quote Originally Posted by ercaduceus View Post
    Thanks for reminding me why I hang out on the 6.5 forums!
    That is hilarious!!!
    Rich.
    May 2007
    Pennsylvania
    Talking
    Quote Originally Posted by ratman View Post
    Rich.
    Not for the guy in the sub-compact! HA HA
    Very sharp, do you still have the interior original?
    Sep 2000
    usa
    Welcome to the 'Page, Knightster............
    Yes, it is the original Sierra SLE interior, dark red, has the factory headliner\trim, power windows, tilt, etc -
    did replace the front bench seat with '90 Astrovan buckets of same upholstery pattern and color, much more comfortable
    I searched and found the Rallye-pak instrument cluster from an '86 305 Blazer, so the tach would be the correct range and appearance, installed and interfaced it to the CPS input in the PCM for accurate rpm indication - installed the quartz speedo from a '91 Sub, as the '95 OBD1 PCM requires digital Vehicle Speed Sensor input, so that is accurate and tuneable for tire-size - eliminated the small, useless clock, installed the Blazer fuel gage in that location, blacked out the "UNLEADED", leaving the "FUEL ONLY" logo - the tach took over the spot originally occupied by the large Diesel Fuel guage - used the 700R4 shift selector quadrant and indicator from the '91 sub, reads Automatic Overdrive - other than that, the instrument panel appears stock behind the '95 GMC steering wheel - those late GM steering wheels have such a manly feel to them, compared to the early versions, don't you think? - very reassuring, in any traffic event.
    I have the new oem replacement for the instrument panel pad, which is starting to crack, but I cannot bring myself to replace the original, as my 5-guage pod mounts atop the pad, right above the main inst cluster, requiring a large hole for the considerable wiring\tubing to pass thru, plus several additional mounting holes - now the add-on guage-pod covers the only cracks in that oem pad - gonna be a big bullet, when it comes time to bite it
    jd
    Sounds like the truck gets a lot of attention, can't wait to get mine to work on.
    Quote Originally Posted by gmctd View Post
    No argument here, I like the 98-02 style best.
    Jul 2007
    lv.nv.
    Cool
    gmctd; very clean mo' sheen! sounds like you did a super custom job on the dash consortium!!!!!!! nothin' like taken pride of your accomplishments!!!
    once i get my scanner back in play i'll shoot some pic's off. take care!
