Does anyone know the proper way to wire up the below two tank valve. IIRC I took it off a late 70s/early80s Chevy. There are 5 wires on the valve and 4 on the factory rocker switch. None of my manuals show this wiring.
Thanks for the help.
1997 GMC Savana - 6.5 TD
1967 Jeepster - Stock
1986 Jeep CJ7 - Stock
HH,
According to my 1983 Chevrolet Helms factory manual:
Pink/Black Right tank level connection (top of tank)
Pink/White Left Tanl Level connection
Pink Instrument cluster
Light Green Dash Switch Right Tank
Dark Green Dash Switch Left Tank
Print also says that this id for all auxiliary fuel tank except RPO LH6 & LL4 (Diesel)
HammerWerf
1999 k2500 Suburban Pyro, Tranny Temp, Boost, K&N Air Filter, +3.5 qt tranny pan. 190000 miles
1984 C20 249k miles DSG gear, SM-465, 3.73
1983 C30 CC dualie. 308K miles on Chassis, TH400, 4-45 A/C Looking for a TurboCharger
Great, Thanks!!
