I think that possibly there is still a misunderstanding of my intake; lets give it another try so there can't be any doubt of what it is.
The intake tubing and billows from the air filter box to the turbo is completely stock, no change in any way.
The air filter box is stock, with the exception that forward upper quarter around the deflection vanes is removed to provide a more direct route for the added 3" supply to flow thru.
A 3" aluminum dryer vent is used to transfer air from the air dam hole (where the recovery hook was removed) running up and thru an enlarged hole behind the headlight and then entering the air filter box enclosure.
The original air breathing holes into the fender well cavity were enlarged and provided about 3 additional square inches of breathing area.
Additional sealing was done around the air box to prevent any air from the engine compartment from entering the air box.
Thats it, a pretty basicly stock system; and really, sans the air filter box the Banks intact tract routing and size is pretty much a mirror of the stock system also.
That cleared up--I hope; it seems a very DRASTIC change moving the MAF from an inside bend location (relatively shielded) to a point where it is getting a direct hit, if you will, from the incoming air charge. From what I have learned here that would seem to really drive things bonkers, no? That is why there would seem to be much more to the system than meets the eye or common conception of its scope.
I notice that there are five wires at the MAF so I presume that it is sending out four separate signals to the PCM.
1. Air flow
2. Air temp. ?
3. ??
4. ??
1. More air flow=more fuel -----provided the criteria is met?
If more air flow is detected but load is light what happens?
In a gas engine a lean mixture equals more heat many times, is it the same with a diesel?
2. Air temp ??? what does the PCM do with that, if indeed that is one of the MAF signals?
3. & 4. Can't ask the question because I don't even know what they are or if they exist.
Bottom line is, I don't mind modifing if I've some grasp as to the workings of what I'm modifing----but in this case it is evident that I don't have a clue. Also it might even be entirely on the wrong track toward correcting my elevated EGT's, water temps, and loss of towing power.
Still need help guys!!!!
