Results 1 to 9 of 9
Thread: converting drw to srw
    Feb 2002
    Texas
    Default converting drw to srw
    I am interested in converting my dually to single rear wheels. I pull a 31 ft camper only 6-7 times per year, and would like to have a smoother daily drive. What would be involved in such a conversion?
    1998 Chevy 3500 6.5TD crewcab dually
    Windham, ME
    I'm 99% sure that the only way to do it is to find a SRW axle. It either has to have the same spring perch spacing or you'll have to cut & weld the spring perches in the right places.
    Phil
    Dec 2006
    Too bad we didn't live closer, I would be up for a swap.
    Feb 2002
    Texas
    Swapping is a great idea....The moving of the spring perches is something I didn't consider, though. I'll have to look into that..
    I think aftermarket fender flares will work once I remove the dually fenders.
    Now on to the front hub/spindle assembly; do they need to be swapped out as well or are there spacers that can be removed?
    Jul 2006
    Fort St. John BC Ca
    Exclamation point to ponder
    are you changing the front also--two different spares
    1985 K1500-sold
    79 dually 4x4-soon to have modified 6.2/6.5l turbo
    1996 shortbox-extended cab 2WD 1500 6.5L
    Apr 2007
    Whitmore Lake,Mi
    Question
    couldn't you just remove a rim from each side
    Jun 2004
    central la.
    the front hubs would have to be swapped the spindles are the same iirc I have a srw 3500
    & would be interested in swapping I am in central louisiana
    cecil
    1993 C2500 HD 6.5 TD TH400 200,000+
    1978 C30 repowered W/6.5 TD turned up max 4 spd
    1996 c3500 cc srw stock sold
    1987 mercedes 300sdl
    Feb 2002
    Texas
    I have actually seen a dually with one tire removed; it just doesn't look right!
    I may get back with you concerning the swap idea...from San Antonio, it looks about 3hrs halfway.
    Once I've found out for sure about the springs and fender flares then I'll be actively looking for swaps (front and rear).
    Thanks for the help, everyone.
    Dec 2006
    Saint Clair Shores, MI
    you need to change the hubs on the front axle to SRW hubs, the spindles are the exact same. you may need to put different rotors on the front, i dont remember if the drw trucks use the same PN.
    for the rear the same thing applies. the hubs need to be changed out for SRW hubs, and the spindles should be the same as well. you will need to change the whole drum brake assembly over to the SRW setup, or go to disc breaks.
    you could just get a different set of rims with the correct offset to look right on the truck and swap the dually rims on when you pull. you can run a dually spacer on the axles so you dont have to have such an extreme offset.
    1985 M1008
    (k30 for the civi' minded people)
    my photo album
    6.2L (banks turbo installed)
    6" suspension lift
    38.5" ground hawg radials on H1 double-beadlocks
    cross-over steering
    rear disc brakes
