Need those codes.
Whenever the trans has a problem shifting or detects a problem with the shift circuitry, it defaults to second gear. This is often confused with first gear. If you can go faster than about 15 mph, it's second, not first.
A common cause is problems with the power to that circuit, which is controlled by a separate set of contacts in the ignition switch. Monitor the voltage at the trans fuse. If it ever drops below 9 or 10 volts, this is likely your problem. but, we need the codes...
