Thread: 4x4 3500HD?
    Hart MI USA
    Default 4x4 3500HD?
    Did GM make a 4x4 3500HD? I just bought a 1994 3500HD and was wanting to convert it to 4x4. Any suggestions?
    Jul 2005
    IL
    Smile
    i have never seen a HD 4x4 however you should be able to put a straight axle out of a older k3500 in with out a lot of work actual kinda sounds like a fun project.
    good luck
    2003 CHEVY 4500 DURAMAX/ALLISON 14'
    SERVICE CRANE BODY 16,500 LBS 14.5 MPG
    1998 K3500 SRW CREW CAB TRANSPLANTED 6.5TD ELECTROINC INTO, HEATH COMPUTER, 40+HP INJECTORS, 4" EXHAUST, VACUUM ELEMTINATOR ON TURBO,UPGRADED COOLING WITH ALL GM PARTS,NO VACUUM PUMP, SST OIL COOLER LINES MADE LOCALY FRACTION OF THE COST, 3" TOURBO/BOOST GAUSGE ALL IN ONE, ADDED GEAR DRIVE GREAT HELP WITH STARTING TIME DOESN'T JUMP AROUND ANY MORE, INTERCOOLER 3" INLET AND OUTLET COOLER 12x24x4, ALSO ADDED MANDEL BENT CROSS OVER, HAD TRUCK REPAINTED AND OPUT ON ALUM FLAT BED
    4x4 was available. I know of a large towing company that had a fleet of them, all OEM. They've gone to Duramax engine late model 5500 and 6500's, but loved the 3500HD's, gas and Diesel.
    Hart MI USA
    What axle was used OEM?
    Beats me. I think there is still a couple around being used by utility companies. If I see one, I'll check.
