Thread: Quick Question...no shift and no dash lights
    Mar 2001
    Smith Center, KS
    Default Quick Question...no shift and no dash lights
    Hey all-
    I have a question regarding a friends 1995 6.5 diesel. He said it has been running fine, but today he got in it and he had no dash lights and the transmission (automatic) will not shift out of 1st gear. Any ideas?
    Thanks in advance!!!
    ** ccole **
    Past Rides: 1978 Chevy 5.7 Dsl; 1982 C-20 6.2L Dsl; 1984 Chevy 6.2 Dsl; 1986 Suburban 6.2L Dsl; 1989 K2500 6.2L Dsl; 1994 F250 7.3L; (2) 1997 F250 7.3L; 2004 Duramax; 2005 Duramax; 2006 Duramax; 2007 Duramax; 1995 6.5 Non-Turbo; 1994 6.5 Turbo; 2001 F350 7.3L, 2005 GMC Duramax (Current)
    It may seem like first gear, but I'll bet it's actually second. If he can get over 20 mph it's second.
    A common cause of this is a failed ignition switch. Check the voltage on the tran fuse. if it is less than the system voltage, that's the problem. QAll he has to so is figure out why...
    May 2000
    Little Neck,NY,USA
    Sounds like your friends truck needs a new ignition switch, try working the switch on and off to see if the dash lights come back on.
    If the trans gets no power from the ignition switch, it will default to second gear.
    The ignition switch failure is not a common problem but a known problem.
    William
    97 Chevy Tahoe 2Dr 6.5 Kennedy Exhaust Pipes w/Homemade Resonator and Flowmaster Muffler, Turbo Tech intercooler and Kennedy/Westers computer
    01 Sunline 2363 Travel Trailer
