I have a 89 chev K2500 with the factory 4 speed manual transmission, has 100,000 original. Have a ton of slop in the shift pattern, if your going down the highway in 4th gear, you can move the shifter about 5 inches each way. Almost impossible to get it into reverse. The is no grinding, or abnormal noise. Is there a bushing or slide rebuild kit? And can it be done from inside the cab without dropping the tranny. Thanks
