Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: EGR on Ca 2003 LB7?
    Oct 2005
    Default EGR on Ca 2003 LB7?
    Today, out of the blue, I had SES light and code P0404 thrown twice. It is EGR "Open condition" related, so I did some searching. I've found info about the EGR and related block off plate for 4.5 to LBZ LLY Duramax engines, but nothing on LB7 EGR. I can't even locate it to check the blue wire that has been mentioned in threads. If anyone is familar with the California spec LB7 EGR stuff to point me in the right direction or to a thread somewhere, I'd appeciate it.
    thanks,
    siggy
    2003 Chev 2500HD/LT/CC/LB7-Duramax/Allison/H2wheels/Bilsteins/Green Keys/195K
    Mar 2007
    Pacific Northwest
    Send me your personal e-mail and I will send you the diagnostic chart for the P0404 for you 2003 CA LB7.
    Dec 2001
    Yorba Linda, California
    Also, keep in mind that the 2002-2004 LB7 EGR that was used in the CA trucks is different than the EGR used in the LLY version. The LB7 EGR is vacuum operated and has a vacuum pump on the passenger side of the engine. The LLY version is not vacuum operated and there is no vacuum pump.
    '02 Chev 2500HD EC/SB 4x4 D/A
    Mar 2007
    Pacific Northwest
    What did you come with SIGGY?
    Oct 2005
    Thanks for the diagnostic chart! I had cleared the codes after reading them and they have not come up again, been almost 1K miles and all is good. I'm wondering if it was a fluke one-time event, or a preview of upcoming issues. This truck has been very solid and reliable so far, my fingers are crossed that things will remain so. 137,000+ happy miles, I keep telling myself I don't need to upgrade to a new truck. Over and over...
    Mar 2007
    Pacific Northwest
    Smile
    I'm glad you like your truck!!
    Myrtlehead, TX
    Siggy,
    My EGR was replaced five monthe ago and the code came again last week. A mech in Oregon took it out and a water cooled pipe that conects to it and cleaned the pipe. It was vety cloged. Hope this helps.
    Mike
    Dec 2001
    Default Egr
    humm egr block off plate .I have an 05 any info would be greatly appriceated. My e mail is olychuckchuck@hotmail.com
    I happen to have an 03 LB7 and have had the darn P0404 code for several months now. I've replaced:
    1997254
    and
    94459951
    If anyone has anymore words of wisdom, I'd really appreciate it. Could I see that diagnostic chart?
    is the EGR supposed to move? This weekend I was looking at it and couldn't budge it...
    anyone?
    Jul 2000
    Gilroy, California, United States
    Have truck in dealer for noise after water pump replacement, belt off sounds goes away we think its the tensioner and are replacing that. Truck also had SES and tech says it has P0404 and P1404 wants to clean or replace the EGR valve. I am wondering if the EGR cooler needs cleaning, truck has 150k miles and usually runs light duty no heavy towing. Also wondering if EGR needs calibration.
    Matt
    mattb5150@hotmail.com
    1993 K2500 HD ext.cab 4x4 - SOLD
    2003 GMC K2500HD SLT EXTRA CAB/SB DMAX/ALLI, Bilsteins, Sulastic Shackles, Pitman & Idler braces, KD Headlight Harness, CAT filtration, Lift pump w/KD harness, Denali Door handles, Yukon exterior mirrors
    2003 Yamaha Grizzly 660 Stoopider FAST
    1996 VW Passat TDI 48mpg - SOLD
    It may only need cleaning. Tough call as to whether it's worth the effort or just write the EGR out of the programming....
    That would be my best suggestion as there are without a doubt more headaches coming.
    Jul 2000
    John, you have mail!!!!!
    Matt
    Jul 2000
    Default P1404
    Can someone elaborate on what is happening when the 1404 code is thrown? Is the EGR not opening correctly? Also I know the EGR on this truck runs off the vacuum pump. Is there anything else that runs off the vacuum pump? If the pump were failing would it cause this code to be thrown?
    Matt
    Jul 2000
    Jim,
    Can you tell me how to check the vacuum? I assume that when the dealer replaced the EGR valve they would have done a re-learn but maybe not.
    Matt
    Feb 2013
    USA New York
    Default lb7 egr delete, light delete istructions
    Quote Originally Posted by Duramaster View Post
    Hi
    I have an LB7 duramax calf. emmis
    Do you have a way to delete the engine light after the block plate
    have been installed?
    My light came on after about 60 yo 80 miles after installing plate,
    Canceled it out. What is EFI LIVE they talk about.
    Thank you
    If you pop over to my web site you'll find my email. Drop me an email.
    Nov 2014
    Default P0404 Code after Vacuum pump change
    I have a 2003 2500HD with the LB7. I just replaced my vacuum pump due to failure. After the pump was replaced, and truck driven a little, the SES light came on. It came up with the P0404 code. I know it has something to do with the EGR but cant figure out how to diagnose the problem. I have read that it might not be the EGR itself.
    The truck seems to run fine, no idle or performance issues. After the code was reset, less than 20 miles later the SES light came back, so did the P0404 code.
    Any thoughts????
    Aug 2020
    Phoenix AZ
    I’ve been having issues with my LB7 throwing ses codes at me. A buddy pulled the code up and tells me I need to clean my EGR, my question is does my 2003 lb7 have a cooler as well? I can’t find them any where. Any help would be very much appreciated. If there’s a better way please help
