Results 1 to 2 of 2
Thread: Power Steering Pump Flow Rate
    Apr 2005
    Toronto, Ontario
    Default Power Steering Pump Flow Rate
    Anybody know what the flow rate is for our power steering pumps? Reason I am asking is because I want to put on a hydraulic winch in the front of my truck and want to match the right hydraulic motor w/our pump.
    1994 K2500 w/6.5 Turbo Diesel
    I used that name because its my username on all my other forums...
    1994 Chevy Sub Diesel K2500
    Apr 2004
    Palm Beach, Florida
    Default Flow rate?
    Dont know flow rate but a MileMarker hydro winch works fine w/stock pump "the issue is cooling PS fluid when pump is tasked w/extra work a PS cooler is required" use biggest that fits.
    Next issue, high idle circuit makes the hydro winch work much better under all conditions.
    Aftermarket high pressure pumps w/remote reservor can be had for just above $300. US.
    Visit Flash Off-road and search through tech section for PS issues and mods that apply to 6.2/6.6 diesels.
