Results 1 to 7 of 7
Thread: Does Anyone Know These GM Part Numbers?
    Nov 2003
    Edison, NJ
    Default Does Anyone Know These GM Part Numbers?
    The part number for the passenger and driver side rear barn door plungers on a Suburban. I’d imagine they are all standard across the same body style. Mine is a 1999 Chevy Suburban “LT”.
    The passenger side has 5 plungers, top 2 are for the passenger side rear window defroster, middle 2 are for the electric locks and the bottom plunger is for the dome light.
    On the drivers side there are just two plungers for the rear window defroster.
    I’d like to order them through Gm Parts Direct as it’s much cheaper than a visit to the dealer.
    Thanks in advance for the help.
    Art.
    Art Paltz
    1999 Suburban K2500 6.5TD (stock)
    2000 Undercover Dragster, 468 BBC, 7.74@173MPH, waiting on new 622 aluminum BBC to be finished.
    1992 Tube Chassis Camaro, 468 BBC, 8.54@157MPH (SOLD)
    1987 Buick Grand National, 11.8@114, pump gas (for sale)
    1969 Camaro SS/RS 396-350HP, stock restoration, it never leaves the garage...
    Apr 2004
    Palm Beach, Florida
    Default Don't know #
    Did you try to clean the plunger contacts w/eraser or very fine grit wet paper? Works well, you can use some di-electric paste on contacts too.........
    May 2000
    Little Neck,NY,USA
    It is called a contact, I can only find a number for the 5 pin on the right side....15693402.
    Info from 97' GM parts book
    William
    97 Chevy Tahoe 2Dr 6.5 Kennedy Exhaust Pipes w/Homemade Resonator and Flowmaster Muffler, Turbo Tech intercooler and Kennedy/Westers computer
    01 Sunline 2363 Travel Trailer
    Nov 2003
    Edison, NJ
    Quote Originally Posted by DA BIG ONE View Post
    Yeah, I tried that long ago. I pulled the contacts out and checked them with an Ohm meter. Gave me the chance to check the wiring as well. Two of the plungers do not work when depressed and pass electricity. I tried a bunch of things to get them working and still no good.
    Art.
    Art Paltz
    Nov 2003
    Edison, NJ
    Quote Originally Posted by diesel65 View Post
    Thanks for the part number. $26, half what the dealer would charge. If I go to the dealer they will probably change me that much for the drivers side. Strange it's not listed as it's part of the defroster.
    Thanks,
    Art.
    Art Paltz
    Nov 2003
    Edison, NJ
    Curious. Do you have a Helm manual? Do they have GM part numbers?
    Art.
    Art Paltz
    May 2000
    Little Neck,NY,USA
    I have the oem parts book for 97' c-k series
    William
