Who?
Originally Posted by
Billman
With all due respect Mr. Moderator...
Who the hell is using a 4L80E behind an 800hp Drag Car?
Turbo 400. Yes. PowerGlide. Yes. 4l80E?
I'm not questioning their durability. Just a first for me to hear it being used like that.
G-car people, hot rodders w/more the 800 hp & wanting OD, the market is so big that adapters for the 4L80 to bolt to almost any engine are the thing these days. Hard part and TC options are staggering I dropped $4,500. last rebuild and will do it again way in the future. The 4L80 built right can stand to even the most high powered duramax, cummins or? The Bentley turbo/supercharged line use the 4L80e as their stock tranny.
