Results 1 to 2 of 2
Thread: Fuel pipes from pump to injectors
Hybrid View
    Default Fuel pipes from pump to injectors
    for the 6.2L diesel, anyone know where i can get a set of fuel pipe that go from the distributer pump to the injectors? Can I use fuel pipes from the 6.5L
    Depending on the year and which heads are on the beast you could use a complete set from a 6.5
    The engines are basically the same. Same parts in many places.
    You can swap heads on most too.
    The Ip can be swapped from a 6.5 to a 6.2 also.
    I have seen a 6.2 dropped in where a 6.5 came from and all the accessories swapped too as well as a DS4 fuel system.
    Watch ebay and craigs list
