Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Whats needed to change fuel filter
  1. #21
    Jan 2007
    I finally checked my filter and drained the non-existent water from the bottom. (just a little humor, I was looking to see how clean the fuel was and if there was any water in the fuel.)
    It took me all of about 3 minutes to remove the fender well, because I knew that I would be down there I cleaned the area the day before. I could have washed it the day of and just moved the truck to a new location so I wouldn't get wet/muddy. I do realize most of the posters here are not in sunny so. florida, so this is not an option.
    I thought of removing the intake (and now the battery) but I actually thought I had more of a chance of messing things up - going from top-side.
    I guess there multiple ways to skin the cat - er. Duramax...
  2. #22
    Dec 2007
    Austin, TX
    Wow, I had a good laugh reading this post. Removing the fender well and specialty wrenches?? You're kidding right?? Why not remove the whole front clip, sheesh.
    One bolt on the battery tray clip, pull it and your done. Unplug the sensor, slide the filter wrench over the wire harness and go. 15 minutes to complete a fuel filter change.
    2005 Chev Duramax/Allison 3500LS DRW Crew Cab, Ride-Rites, Sulastics
    B&W 30K-Turnover GN, Putnam 15K-Class-5, A/T Revos, LMM mouthpiece
    2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 8'Flat-GN, Ride-Rites, Sulastics
    A/T Revos
  3. #23
    busted up a few of the pegs that hold the fender liner in............anyone know the part # for these pegs that hold the fender liner in?
  4. #24
    Maplesville, AL - Home Base
    Thank you Hook_'em_Horns! This is the easy way for me.....take out the right hand battery. At least I'm not the only one. Ed
    Ed
    KM4STL
  5. #25
    Jan 2005
    Default Fuel Filter
    I bought a 2002 2500HD and there wasn't an owner's manual with it to show me how to change out the fuel filter. The info in this thread seems fairly clear but I'm a little afraid of messing something up because it appears I have plent of room to change the filter without removing fender skirts, etc.. Is there a place I can see some pictures of the fuel filter and it's location on a 2002 model? Am I just being to caustious and making a mountain out of a mole hill?
    I have never gotten a wif alarm indicating that there would be water in the fuel. I probably have close to 10K miles on this filter.
    Is there a rule of thumb for how often the filter should be changed?
    Thanks for any help you can give. Sorry if the questions are dumb, not many mechanical skills here.
    Knapper
  6. #26
    Jack
    The earlier the model, the more room there is. If you think you can do it w/o removing anything, go for it. I've replaced dozens of these on just about all models, and I can get them all from the top (some require a little assistance through the fender liner, like a 2003 CA model last week). Your 2002 should be easy to get to w/o removing anything. Do yourself a favor, though, and drain the filter before pulling it. If it's full, it'll spill fuel all over the place. Use a piece of hose that will fit over the water drain nipple and open it and the top bleeder. Drain into a suitable container. No mess! Don't forget to disconnect (then reconnect later) the WIF sensor harness. If it gets tangled in the works or your wrench, you'll be shopping for a new one.
    Don't complicate it any more than you think you have to. Glean what you need from the above suggestions, and keep it simple.
  7. #27
    Jul 2007
    ortonville, mi
    I did mine from the top, did not remove anything, no help from anyone, piece of cake
    http://www.thedieselpageforums.com/tdpforum/image.php
    07 GMC CC SB LBZ
    70 monte carlo, original 4 spd, bench seat
    71 monte carlo SS clone, street/strip
    97 grand am, beater
  8. #28
    I always remove the right hand battery. Two cables (yep I tape up the hot lead) and one bolt and out it comes. Then I have plenty of room and I'm not trying to work through the a/c lines. Ed
    Ed
    KM4STL
  9. #29
    I can spin one off and spin one on by hand on any of our trucks in about 10 minutes now. Substitute Mechanix gloves for the filter wrench... I still like my overpriced WIF remover wrench. Have one in each truck, with a spare filter of course.
  10. #30
    Jan 2005
    Default Whats needed to change fuel filter
    Thanks folks. Got it done today. A little learning curve but not a big chore.
    Thanks for your help.
    j
  11. #31
    Quote Originally Posted by DarylB View Post
    Much too long, here's the simplified version:
    1. Drop the Passenger Inner fender
    2. Unlpug the WIF sensor
    3. Twist off the Old filter
    4. Install new fuel filter & O-rings if applicable. Reconnect WIF sensor.
    5. Open Bleed Screw and Prime w/ the Pump, close bleed screw
    6. Crank engine, check for leaks
    7. Re-install inner fender & Enjoy!
    ** On a site note ** Thanks Duramaster, I may try the intake-removal next time around. I hate those little plastic pegs you've gotta pull on the fenders.
    I'll add that I do all of mine without tools now. Hand tighten the filter and finger tighten the bleeder. Keep a strap wrench and nut driver handy in case you cannot remove by hand. Never use a screwdriver on the bleeder.
    Quote Originally Posted by deerhunter7 View Post
    I was wondering if they make a special tool for removing the pegs out of the keeper. Prying them with screwdrivers gets hard on the hands ..
    Get a can of CRC spray dielectric grease and spray the pegs. They'll slide out like you wouldn't believe the next time...
