Results 1 to 18 of 18
Thread: Manual Glow Controller :)
    Default Manual Glow Controller :)
    So I did it yesterday, got some good copper wire, a Ford starter solenoid from a 1970's Big Block, a nice illuminated spring loaded toggle switch, and some good electrical connectors from the electrical supply house.
    I can't take credit for the design but there are a few things I learned here. Being an electrician, I know the importance of a good solid electrical connection. There's no substitute when doing anything electrical, never cheap out and buy rinky dink connectors. If using stake-on fork or ring terminals, buy a GOOD set of crimpers don't hack it in with cheapo pliers.
    Anyway, I followed some info I got in one of the post here, and ran a new number 6 copper wire from one side of the new solenoid direct from the battery. Then from the other side of the solenoid to the factory 1988 glow plug controller. Use a 1/2 inch wrench to remove the 2 little grey wires on the load side of the factory controller. CLEAN them with a small file, then install your brand new wire from the solenoid to this controller then reinstall the 2 grey leads which feed your glow plugs... make sure you have a good lock washer in there.
    I ran a number 12 stranded wire into the cab of the truck for the switch with an inline 20 amp fuse. Come back off the switch from the ACC thats stamped on the switch to the new solenoid small terminal marked "S". Leave the one marked "I" alone. The old ford solenoids are grounded through the base of the solenoid so if you mount this against a good grounded piece of metal under the hood there's no need to run a ground back to the battery. The BEST thing to do here would be to find a good grounded piece of metal accesible from both sides to nut and bolt the solenoid to. Then run a number 12 awg wire from one of the mounting bolts direct back to the battery. Make sure you ground the switch inside the cab if neccesary.This is simple run a new number 12 awg wire from the ground terminal on the switch to a nice shiny spot that you just scraped with a file under the dash and connect a nice new ring terminal to finish it off. Guess what, when you just strip the wire about an inch and crank a screw down on it thats hack, give yourself a good ground.
    Now comes the good part and a comparison too. Turn on ignition, let factory glow controller do its thing, but watch the volt guage on the dash. It jumps down quite a bit. After factory glow cuts out bang your new switch and watch the meter again, it comes down half as much, this is EXACTLY what you want. This also allows you to glow your plugs before even turning on your ignition. But wait, the way we wired it the WAIT light on the dash still comes up Nice.
    Its a fairly cold day today in Rhode Island, about 27 this morning when I started up the dually, it never started so good. I glowed it with AC60g's for a while and it started up within 2 revolutions, with zero smoke, what a blessing. Ill post some pics in about an hour or so. Total time to install, about a careful hour. And don't forget to be careful with the factory glow controller when working on it, one side of it has 12 volts waiting to bite you hard at all times if you don't disconnect your batteries. Hope this helps.
    1988 C3500 2x4 extended cab 6.2 N/A TH400 Dually
    Nov 2007
    Port Huron, MI
    could you email a copy of the digram or whatever you used to do this. thanks
    allformike@comcast.net
    89 K2500 6.2 4X4 3/4 TON 4x4 TH400
    87 DODGE D50 360 727 TORQUE FLITE FORD 9'' MANY MODS--- IT'S FOR SALE
    Dec 2006
    This is exactly what I was looking to do, anybody done this with a 82-84 system? The controllers seem much different, or can you just tap into the relay on the fender? I suppose some further research and wiring examination is in order, sounds like a terrific mod though...
    -Martin
    '82 K5 "Durasaurus" Blazer, Newly rebuilt 6.2, 6.5 heads, 90 ld DB2, 6" Pro Comp Lift, 35" BFG Muds, Rustoleum Rattle Can deluxe
    Quote Originally Posted by mstockton View Post
    -Martin
    The 1982-84 glow systems are the easiest to convert to manual glow. The separate relay is already there... Just wire in a switch to the control terminals on that relay (switched 12v ignition & ground). The "Wait to Start" lamp on the dash receives power from the harness that powers each glow plug, so it'll work like you expect without doing anything special.
    Nov 2006
    Which of the 2 small terminals would you wire in the power side? Wire color? I would like to do the same in my 84 since I installed 60G plugs with the factory controller and relay before I found this site. It starts in 30deg weather but she struggles if its not plugged in
    1984 K2500 6.2 AOD
    2001 Dodge Cummins
    Too many Mustangs
    Brighton, CO, USA
    It should be like the original one on my 82...
    The terminal toward the front of the truck is hot when the key is turned to run. The terminal toward the windshield is grounded to close the relay contacts, so the easiest way is to wire a momentary push button switch to the back terminal, connected to a suitable ground.
    To use it, turn the key to run, push the button to complete the ground and the glows activate. This should also turn on the glow plug light on the dash.
    Hope that helps.
    Joe.
    2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
    1996 Chevy C2500 6.5 auto Ext. Cab LB
    Default check this out
    Quote Originally Posted by Mikeandwendy74 View Post
    http://www.youtube.com/watch?v=oJq5LdAGor0
    heres a video of the controller very easy to make.
    Aug 2014
    Panama City, FL
    Default Hmmm . . .
    Does this apply to the '82, wondering as another post here said that one was simpler?
    1982 K5 Blazer 4wd w/ 6.2 turbodiesel (Banks Sidewinder) w/ rear disk brakes, more to come . . .
    Loyal WI US
    On my '84 I used the 85-93 glow controller and then added the resistor mod. Both of these were outlined in the Feature articles back in the day. This combined with my Quick heat glow plugs got me fully automated reliable and consistent cold starts at about any temp. It also made it so I could trust just about anyone start the truck without fear of issues.
    Default controller
    This is a great post!
    I watched the video http://www.youtube.com/watch?v=oJq5LdAGor0
    but I am curious if anyone knows which wire and what size resistor to use to lengthen the cycle to around 10-12 seconds.
    thanks
