Brake line fitting size?
Im going with ss braided brake lines but forget what the fitting sizes are?
I can get the SS braided hose in different lengths w/90% or straight -3, or -4 AN ends from here I need to use adapters to my calipers, and rear line to brake block on differential.
Its a 99 6.5td burb
