Results 1 to 20 of 22
Thread: 4l80e and 1989 6,2D
    Sep 2006
    Norway
    Default 4l80e and 1989 6,2D
    Hello.
    I've replaced the tranny in my 89' G30 6,2 Van from a 3-speed to an 91' 4l80e. This seems to work fine, speedo works and I don't get any error codes in the system.
    But I have one question. When I floor the throttle, the tranny shifts from 1-2 at around 42km/t (26mph), and from 2-3 at 82km/t (51mph). I mean it should go up to around 60km/t (37mph...) before it shifts from 1-2, and close to 100km/t (62mph) before it shifts from 2-3.
    Isn't that true? I'm not sure any longer
    I tried adjusting the TPS, but still the same.
    Apr 2004
    Ottawa, Ontario
    What controller are you using to drive the new tranny. If it is looking for some engine components that aren't there then it may have gone into some form of default mode.
    Bill
    94 Cadillac Fleetwood (sold)
    08 Aerolight 23TT
    Sep 2006
    Norway
    Hey.
    Im using the original TCM that was previously used for the transmission when it was in the "part car". Ive transfered all the wires from this TCM from the "part car" and over to my 1989 Van, including the VSS and so on.
    I hope you understand what Im writing here... :-)
    Apr 2004
    Ottawa, Ontario
    I guess what I'm saying is what was your original "parts car". That will dictate how the TCM/ECM was originally programmed. If the parts car was a gasser then the ECM is also looking for:
    Manifold pressure
    Mass airflow
    O2
    Engine temp
    TPS
    Engine speed (RPM)
    Even if the parts car was a diesel, it may also be looking for EGR and it will definitely be looking for an engine speed sensor.
    If it does not see any of these inputs, it will more then likely go into one of the default modes that will directly effect how your tranny shifts and weather or not the torque locks up.
    Bill
    08 Aerolight 23TT
    Any idea what RPM it's shifting at? MPH depends on the transmission ratio and rear axle ratio.
    Sep 2006
    Norway
    Manifold pressure
    Mass airflow
    O2
    Engine temp
    TPS
    Engine speed (RPM)
    Bill
    Hello.
    The parts are coming from an 2 year newer car, (1991) witch is also an 6,2l D G30 Van.
    I havent thought about that it might be looking for EGR... Do you think that might be the reason?
    Engine speed sensor is moved over. I guess my speedo wouldn't work if this speed sensor didn't work... The instrument panel is moved over from the part car, speedo and so on, because my old speedo was linked to the old transmission by a wire.
    Sep 2006
    Norway
    I don't know, but I would have liked to known
    This transmission have the same gear ratio as my old one in the first, second and third gear.
    Apr 2004
    Ottawa, Ontario
    Okay two things
    Are you sure you have a 4l80E? Personally I have never seen the 4l80E in anything older then a 93. Doesn't mean they didn't exist, just that I have never come across one. More then likely you have the 700r4. How many wires are coming out of the side of the tranny? The 700 has only 4 or 5 (2 for the VSS and 2 or 3 for the lock-up). The electronic tranny will have a sizable bundle of wires coming out of it (not sure how many).
    The engine speed sensor is either a seperate wire coming from the alternator or a sensor built into the oil-pump drive located at the back of the engine in the valley on the right hand side. Should have two wires coming out of it. This is not the "vehicle speed sensor" that is mounted to the tranny. That is used to drive the speedo. The one I'm talking about only senses the RPM of the engine.
    Bill
    08 Aerolight 23TT
    Nov 2000
    Beltsville MD USA
    The 4L80E trans was installed in the 2500 and 3500 trucks , vans in 91 . His system is very simple only needing RPM , TPS and the electronics to run the speedo . I have a 95 system and the only sensor in addition to the above is a baro sensor . No EGR is used . This is on the 6.2/6.5 Y engine in the van . i just picked up a harness for a 91 Suburban with a 6.2/4L80E combo and that does not have EGR .
    Apr 2004
    Ottawa, Ontario
    I stand corrected. You learn something new everyday.
    That would mean that there are a number of these standalone controllers just sittin around in bone yards. Certainly better then the 1000 clams the aftermarket is getting for these controllers. Maybe a viable alternative for my B/D chassis conversions. Anyone have a list of the chassis these were used in?
    Bill
    08 Aerolight 23TT
    Nov 2000
    Beltsville MD USA
    I've seen them listed for parts up to 97 in bread trucks . The G vans are an engine code Y , that means 6.2/6.5 NA engines . If you find one with a turbo , keep looking as the ECM also operates the DS4 . Ebay has a TCM right now for sale . The 91-93 TCMs were the same , 94-9? had a different part number . Keep the years the same as the TCMs went to a different baud rate ( as per Bobbie Martin ) after 93 .
    Sep 2006
    Norway
    Okay two things
    Bill
    Yes, I am pretty damn sure that it is an 4l80e This I have checked and rechecked during this project.
    But you are saying that there is 2 speed sensors, vehicle and engine speed sensor, and the one that is "driving" the speedo is locaded on the transmission. This is interessting... Now Ive got something to check, maybe it is this engine sensor that is not working correctly, this sensor on the rear of the engine with 2 wires going from it.
    But the roads here is damn icy at the moment, so I guess I should wait a few days before testing
    Frank
    This is interesting and possibly it is a production anomaly.
    I had a 91 Diesel Burb and it had a 400 in it. Dont think it was a retrofit either.
    I had another 91 Burb that had the 700R in it. 1500 series though
    Was the 4L80 an option or ???????
    Nov 2000
    Beltsville MD USA
    The 400 should have been a refit . Could check the VIN to make sure it wasn't a late 90 . I had a 2500 Suburban fire truck that had the 4L80e , have a 5.7 with one in it sitting in the yard now beside a 3500 crew cab with a 5.7 and the 4L80E . Really , how would you know that the TH400 was a refit ? Lengthen the drive shaft and move the cross member forward and it looks right . I pulled the shift linkage off and that was only about 2" longer than the TH400 and the cross bar looks like a TH700R4 side by side . The support for the " Z " bar is a little taller and wider but I did talk to someone that just used the 700 stuff and it worked . The harness that I just got was supposedly from a 91 Suburban 2500 with the 6.2/4L80E combo and I believe it . There is the plug for the trans , both speed sensors ( big tip off as the 700 only has one sensor ) , glow plugs , TPS , fuel filter , engine RPM , etc . The option code is also correct , MT1 . The 700 is MD8 .
    I should have added the 4L80-E only went into the 3/4 or 1-ton models.
    I saw a 1991 diesel Burb a couple of years ago that was in for trans service at a local trans shop. It had the OE 4L80-E.
    Mar 2004
    Norway
    Hi, I can see one right now, trough my officewindow.
    Hei Frank, vanskelig for disse amerikanerne å få inn i hue at Suburban kom med denne kassa i -91.
    Sub6291 på offroad.
    Sep 2006
    Norway
    Now I've just checked my wiring to the Engine Speed Sensor, and found out that there maybe was some wrong there, but I corrected this using the Fig 15 on this page, http://www.autozone.com/az/cds/en_us...rInfoPages.htm
    So I am now pretty sure that my Engine Speed Sensor is connected correctly.
    But when I took it for a spin today, it still shifted at the same speeds as before. So maybe my Engine Speed Sensor is not working as it should...
    Nov 2000
    Beltsville MD USA
    You should have an engine speed sensor and 2 trans sensors .
    Nov 2000
    Beltsville MD USA
    Just took a look at the wiring from Autozone . That's not what I'm used to looking at . What year is yours , 91 ?
