Results 1 to 6 of 6
Thread: 2006 LBZ in Limp Mode?
    Jun 2007
    North Bay, Ontario
    Default 2006 LBZ in Limp Mode?
    My 2006 LBZ just went into limp mode! My Helm's manuals haven't arrived, and the dealer is being uncooperative regarding scheduling. The truck was running fine this morning. the second start of the day the CEL light came on and now the truck is holding the RPM up and shifting funny any suggestions as to where to start looking would be greatly appreciated.
    I do realize that there is not much to go on. So thanks
    The truck is bone stock, no mods whatsoever and only has 75000km on it.
    Nov 2007
    Tulsa, OK
    Mine did this when my #7 injector pigtail shorted and failed. Free dealer fix. Might check your injector connections. Wiggle them and see if that helps. I think you will need to disco the batteries after you play with the pigtails.
    '05 CC 4WD "Duallie" LT Loaded D/A
    '94 7.3 Turbo, not PSD Ex-Cab 5 spd "Duallie"
    '03 Silverado Ex-Cab 5.3
    '66 Ford Short Bed 6/3 on the tree
    Did the temperature just drop? Change the fuel filter!
    Jun 2007
    North Bay, Ontario
    The outside temp acutally went up. I picked up a fuel filter so i might as well change it.
    Jun 2007
    North Bay, Ontario
    Fuel Filter changed no joy! the engine light goes off then back on within seconds
    Jun 2007
    North Bay, Ontario
    I got in to the dealer this morning they said tey found a U0100 P0700 code set cleared codes and said it was my strating sequence that has caused the codes and the limp mode. It sounds a bit foolish to me anyways the truck runs fine now. I am looking at EFI Live but is their anything else out there that will allow you to down load codes and clear codes?
