I just replaced both rotors on my 96 Burb 4x4 and need to know the torque spec for the 36mm axle nut and the 4 15mm bolts that hold the bearing assembly to the spindle.
04 Chevy 2500HD 4X4 LLY DMAX LS CCSB
00 Dodge 2500 4x4 CTD
86 K5 Blazer 4X4 NA 6.2 aka CUCV M1009
57 Chevy 210 1ST CAR
88 Jeep YJ 3/4 axles & SBC
Mark
36mm axle nut = 160 ft/lbs
4 15mm bolts = 133 ft/lbs
1994 K1500 Blazer: 6.5L TD/4L80E: 'F' intake: Kennedy chip: Kennedy 3.5" exhaust: Heath Turbo-Master: 2/0 battery cables: Lubrication Specialist oil cooler lines: Fumoto drain valve: Amsoil dual bypass remote oil filter kit: Fluidampr: 137k miles
Thanks alot. Now I can finish up in the am.
Mark
