Results 1 to 6 of 6
Thread: 1993 2500hd
    Nov 2006
    Kelowna, BC
    Default 1993 2500hd
    This is my truck which I am slowly doing up as finances permit. The plan is for an engine rebuild in the spring.
    Thumbs up
    Nice looking truck! What size tires are you running?
    Nov 2006
    Kelowna, BC
    Default Tires
    36x12.5 on 16.5 Rims, no lift
    Apr 2004
    Palm Beach, Florida
    Question Rims?
    Quote Originally Posted by 6.5 Detroit Diesel View Post
    Which rims are you using, what specs?
    Nov 2006
    Kelowna, BC
    Default Tires
    To explain properly. I purchased the tires for $100 for all four. They were basically new and the seller didn't like them because they were to noisy for her Hummer. I went to the local wreckers and found four 1 Ton Chevy 16.5 rims to mount them on.
    I love the custom touch on the hood (Scoops)
    Robyn
