About a week and a half ago I started hearing an odd rattle in the DaHooooley.
Seemed to be metalic and located forward from the driver.
This little gremlin would come and go on any rough surface including just driving over a heavily marked cross walk.
A trip under the truck with a flashlight did not reveal anything of substance but did allow me some time to look around.
yesterday the weather cleared off for the first time in weeks so I decided that this thing had to be fixed.
A trip off down the gravel road finally turned up one hint as to the possible cause of the issue.
A very light application on the brake pedal would stop the rattle right quick.
Ok Off with the front wheels and a good look at the brakes.
Now I had replaced the pads about a month ago and all seemed fine then, but I only slid out the old ones and then compressed the piston and installed the new pads.
The weather was wretched that day so it was a quicky.
Now as soon as I get the RF wheel off I notice a rubber tube protruding from the lower retainer bolt on the caliper.
A more thorough inspection revealed this tube to be the rubber bushing that the retaining bolt and sleave go through.
The caliper was loose and rattling around on the pins as not only was the one bushing hanging out but the other was also compromised.
A quicky trip to the Napa store retrieved a set of new bolts,sleaves and bushings.
A short time later with both sides seeing new parts the nasty little rattle is no longer there.
I was amazed at how much noise that little issue could cause.
