Misfire detected is back
Runs great, and I'm stumped!
I cleared the ecm and drove awhile and the misfire is again detected only code I have is recurring code DTC 1656 boost solenoid control circuit however this circuit is functioning.
I'm going to change out Heath Stage 3 ecm today and go back to my L65 HD ecm then drop boost and see what happens from there.
I'm curious if the timing gears built in 2deg advance have anything to do with this issue?
Reason: add
