SES is present
Originally Posted by
DmaxMaverick
Yep. If you are getting WG faults, and have no pump, that would explain it. Are you seeing the SES? If not with the BH computer, the code may be present, but w/o the SES. Poor programming, IMO, where the SES is masked, but the code isn't addressed. Seen it before with BH programs.
Guess I'm not going to get the DTCO KoKo to do its job w/the DTC1656 repeating every time the key is cycled 2 times.
