Results 1 to 7 of 7
Thread: 04 Wheels on a 98
    Feb 2008
    Kentucky and Clemson SC
    Default 04 Wheels on a 98
    Will the wheels of an 04 2500 fit on my 8 lug 98?
    Sold: 98 2500 ext cab long bed 4x4 auto 166k, Lubrication Specialties oil cooler, FSD cooler, Walking J "feed the Beast" mod, Heath HD lift pump, SSdiesel turbo back exhaust, Heath mechanical boost controller, Softtopper camper top, boost, egt, fuel pressure gauges
    1970 El Camino SS, built 355, aluminum heads, Lunati cam, intake, 800 cfm edlebrock, Tremec 5 spd, QA1 Coil over all around, Wilwood discs up front, 3.73 Posi 12 bolt, Viper Red
    2012 Audi A3 TDI- Love it! 45 mpg!
    May 2002
    Portsmouth Ohio
    Yes, several have made the swap
    96 GMC 2500 Ext cab Long bed, 8600#, 3.73, Amsoil air filter, amsoil oil, amsoil trans fluid, 3.5 Kennedy Exhaust, 97 airbox mods, EGT, Boost, & Trans Temp on pillar, Heath bumper mounted FSD. Pulling 28' Sprinter 5th
    Nov 2007
    Why do you want to swap? Is there an advantage?
    Joe
    Quote Originally Posted by Kmehr View Post
    ****WANTED BURNED OUT PMD/FSD MODULES FOR EXPERIMENT. ****
    1998 Silverado, 6.5TD, 210k, long bed. 1984 Chevy Customized Van, 6.2.
    1985 Mercedes-Benz SD, diesel, 220k
    1990 Ford, F-250, 7.3 liter, bad engine.
    Onan, 4 cyl. Diesel, Marine Generator.
    Onan, 4 cyl. Diesel, Stationary Generator.
    Onan, 4 cyl. Diesel, Air-cooled Engine.
    2 Briggs/Faryman Diesels to rebuild.
    Oct 2007
    Gridley, CA
    Cause they look cooler than the stock steel rims. I got these ones from Les Schawb for $200.
    94 GMC 2500 HD
    Ext Cab, Long bed
    6.5TD, Vin F, 4L80E, 3.73 gears
    Pinnacle 4" Exhaust
    Heath Diesel Turbomaster
    172,000 miles
    Nov 2007
    Oic. They do look nice.
    Joe
    Quote Originally Posted by Kenneth View Post
    Feb 2008
    Thanks! I like the looks of them a lot. That is a really good deal for $200. The cheapest I can find on craigslist or junkyard (car-part.com) is 400. Any other good resources or places to look? Thanks
    Oct 2007
    Gridley, CA
    Go check out different tire shops. A lot of guys are trading in their "stock" HD rims when upgrading. Les Schwab, Firestone, Big O Tires, etc., usually sell them cheap cause they're used.
    94 GMC 2500 HD
    Ext Cab, Long bed
    Pinnacle 4" Exhaust
    172,000 miles
