Originally Posted by
Burning Oil
As long as you get all the parts that go with the adapter for a manual trans you will be fine. The crank Hub will give you the proper spacing. Actually I think all you need is the adapter and hub and I think one for an auto should work also. Your flywheel will bolt to it. One thing to make sure of is if your flywheel bolt patern is the same as the crank hub. I have one I can measure if you need.
