Originally Posted by
Gearstix
I'm worried about mechanical failures and stuff, and expensive repairs.
I think I'll try to find a truck with a 6.2L... but might be hard... and might have a billion miles on it.
I'm gunna wait though and see if we move, if we move I'll have space to pull an engine. How difficult would it be to rebuild a 6.2?
Was there ever a factory turbo variant? Would it be worth it to turbocharge a 6.2? I don't think I would but, just curious.
Mechanical failures in my opinion are cheaper than the electrical ones associated with the newer diesels. The old 6.2's worked well and most of them last a long time. The injectors for a 6.2L are around $50 a piece whereas a set for a Duramax are closer to $400+ each.
A 6.2 is no harder to rebuild than a 350 gasser, in fact I thought it was easier. Here's a decent breakdown on what a rebuild will cost you. At least this is what it cost me in Alaska (where things are normally more expenseive) only a year and a half ago.
Block prep (machine shop will do this and will bore it out if needed) $500 they also installed new cam bearings and checked my crankshaft for this price.
Rebuild kit $900 (had the machine shop order this, for .030 over as that's what the block needed to clean the cylinder walls. It included 8 pistons, all new bearings, seals, gaskets, and frost plugs. I think that's all that was included, I could be wrong.
I paid $15 each for the machine shop to verify my heads were crack free. The main problem was that I had to pull all the valves and springs. The nice part was the shop tanked them, tested them, and put in new stem seals while I reassembled them at their shop.
I had a great machine shop with a great reputation, make sure you find one that has experience with diesels.
Add to the prices $320 for new injectors, $250 for an injection pump rebuild, a $80 set of new glow plugs, a $40 radiator power flush, and about $120 for new fluids, including an extra oil & filter change done after the first 200 miles.
These are some of my favorite trans guys. Bowtieoverdrives.com Done business with them and their products are top notch. Their level 1 kit would handle a 6.2L no problem. Just specify the 1200 rpm stall converter when ordering. For $1K, it's a good deal. You'll pay several hundred for a trans that shifts and who knows what shape it's really in till you've had it a few months. Their lockup kits are great, I've had them in five different 700R4's and by some miracle, none of them has given up, even the one that pulled my 10K trailer from Alaska to here.
