http://http://edmontonjeep.com/forum...pic.php?t=4652
here you go for $800........i'm not sure if its still for sale or not though.
hmmm.
I'm not really sure if I can get a trailer to tow now.
If I do a diesel swap, I want to figure out everything I need.
I'm worried about a transmission. Not sure what will fit, or work. I'm not sure if I want automatic or stick. Its a stick truck now, so would I be able to retain all the pedal and stuff now? I got the rear end figured out. I'm going to use a 4x4 94 up i think ford explorer posi rear.
I would like to use a four cylinder, because its not as heavy (don't think so at least)
Id like to turbo it aswell.
I'm thinking if I were to do a V8 diesel it would be a 6.2 with 6.5 or homebuilt turbo setup.
theres alot of things I'm not 100% sure about.
Went to the NADP August blackout. I love the power that diesels put out, the turbo spooling, the smoke, the noise. I would love to have a diesel in my truck.
A Toyota diesel would probably a decent setup. Toyota engine, and whatever transmission will fit that. I'd definitley want a turbo.
Found a 1L toyota diesel in Calgary, with trans but trans needs to be rebuilt. Comes with mounts, rad, intake, wiring, glow plug gear... might buy it..
Check on parts availability for the tranny. My Toyota shop - I've been friends with the owner for years - steered me away from a Toyota motorhome because the transmission is almost impossible to get parts for.
I have a 1984 Toyota 2wd pickup with a 2L (2.4 litre, 2L is just the engine name). Its in pretty darn good shape for its age and it starts and runs like a clock......and your in luck because I'm kinda wanting to get rid of it.
You can send me an email at ssapach@hotmail.com and I can send you some pics if you like.
If you seriously want that engine in your chevy, it will have all the parts to make it run. It would just seem like a shame to rip apart a truck like that just for an engine.
I have this thing posted up for sale a few places. So, not to be pushy or anything, but first guy wanting it bad enough and has the cash gets it.
hmm. I'm not really sure if I'd be able to buy the stuff from you gopher.
Don't take it off the market.. if it sells and I don't buy it, Oh well.
I've got another 6.2 question.
If I get a 6.2, could I use a small block chevrolet transmission, that would have been bolted to a gas engine?
ΜΟΛΩΝ ΛΑΒΕ
