This is in general, but wheels are mounted either "hub-centric" or "lug-centric". My old motorhome was hub-centric and I had to have spacers machined when I went from 16.5" wheels (several warped, and no longer made) to 16"s. My current coach has 19.5" lug-centric wheels, which is why the torque specified is >400 lb.-ft.
You need to know which you have (it sounds like hub-centric) before you use aftermarket wheels, but good luck getting a straight answer from anyone...
