Happy Holidays!
This month's USDieselParts.Com specials are available only to our Newsletter Subscribers! These items are discounted below the prices that we are allowed to advertise to the public, so we are offering them only to our Newsletter Subscribers. We have included some lower priced items that will make great stocking stuffers for gearhead that already seems to have everything.
Don't forget, we also have VisionX Lights and Accessories at 10% off, and Brite Box Light Modules at 10% off. These are available to everyone and can be seen here.
$341.28 Save 10%
Newsletter Special: $307.15
The latest innovation from BD, the Super Air Scoop replaces the passenger side fender air vent on the 6.4L Power Stroke with a ram air style scoop and ducting with reduced bends, increased diameter and smoothed-out corners that access more cool ambient oxygenated air – improves fuel economy, lowers EGT’s & emissions and turbo response time for quick power increases. This easy to install kit comes complete with all hardware, a washable performance air filter and filter cleaning kit.
Newsletter Special: $55.47 - $72.30
Get more performance out of your electronically controlled Dodge-Cummins or Ford-Power Stroke engine by plugging in one of BD’s Electronic Boost Builders. Installed inline with the MAP sensor, the Electronic Boost Builder increases boost pressure and intercepts the message to the ECM, preventing it from setting an overboost trouble code that can cost between 50-80 horsepower. BD’s Boost Builders are a perfect match for engines with power module, injector or turbo enhancements.
1999.5-03 Ford 7.3L Power Stroke
On Sale! - 10% Off
Now Only: $78.19
This compressor wheel will fit the existing turbo on all 1999.5 – 2003 7.3L Power Stroke engines. The unique design of this wheel has been found to help eliminate turbo stall & lag and absorb 50% more air than the factory compressor. While not necessarily gaining more horsepower, it will simply get the horsepower you have to the wheels more quickly and help reduce EGT's (Exhaust Gas Temperatures).
Your Price: $151.30
10% Off - Now Only: $136.17
BD’s adjustable Waste Gate Kits keep the bypass valve closed, raising boost levels for increasedperformance and helping to prevent waste gate “creep”. These kits include stainless steel brackets and a high temperature resistant Nomex diaphragm with a heavier spring andlocking jam nut for precise boost pressure settings.
15% Off - Starting at $126.65
Add fluid capacity to your transmission. Extra fluid means more cooling, more cooling means better efficiency and performance. No modification to dipstick required. Pan features built-in drain plug & mounting hardware. Add life to your transmission with a B&M cast aluminum deep transmission pan.
(Including Hemi)
Your Price: $263.50
10% Off Now Only: $237.15
BD’s Short Shift kit for Dodge five and six-Speed transmissions puts the fun back in your driving by reducing shift lever travel by 20%, resulting in faster, more positive shifts. The kit includes everything you need for an easy, do-it-yourself installation, including a billet aluminum shift plate, forged steel shift handle and high-strength fasteners.
High Idle Control Kits - Duramax
Your Price: $23.80
10% Off - Now Only: $21.42
Easy to install switch that will activate the high-idle mode on the Duramax engine for quicker warmups in cold weather or PTO operation. Helps extend engine life.
Dodge Ram Steering Stabilzer Bars
(Gas & Diesel)
Your Price: $212.50
10% Off Now Only: $191.25
BD’s Steering Box Stabilizer (SBS) eliminates steering wander and wobble caused by excessive shaft play in the steering box of late-model Dodge trucks. Designed for easy, bolt-in installation in about 10 minutes, the SBS virtually eliminates frame flex at the steering box mounting point, resulting in more positive steering feel. The BD SBS is black powder coated for corrosion resistance, and features a greasable, high-quality bearing for reliable operation. The SBS comes complete with high-strength mounting hardware and instructions.
www.usdieselparts.com
(800) 823-4444
