Overland Diesel swapped a VW diesel into a Jeep CJ3b. They made a custom adapter to fit the engine to the T90 transmission.
Acme adapters makes an adapter kit for a VW to a Suzuki or Toyota drivetrain, so that may be an option.
IMHO, I think the 6.2 or 6.5 is suited for a Wrangler, and most of the small block adapter kits will work with the 6.2 & 6.5s. If you gear it right and keep your foot out of it you should be able to get at least 25 mpg.
1997 GMC Savana - 6.5 TD
1967 Jeepster - Stock
1986 Jeep CJ7 - Stock
