Mark, Great idea on this thread. My truck’s history is as follows:
1. Year/Make/Model truck
2003 Chevy Silverado 2500HD LT Crew Cab Short Box – currently at 82,000 miles. Except for being a little louder (fuel knock) the truck runs as it did when new. Mileage is 17-18mpg with mixed highway/city driving and 19-20mpg highway. Balance rates have increased but are still in spec. I’ve used Stanadyne Perfomance formula and a lubricity additive since the truck was new. First 30kmi was with with 4oz of 2-cycle oil/15 gal then switched to Stanadyne Lubricity Formula.
2. Engine code (LB7, LLY, LBZ, LMM)
LB7 Federal Emissions with no CAT or EGR
3. Type of additional filtration added, and at what odometer reading
- 6019 miles: Installed Kennedy Mega Filter (Baldwin BF7635), Post OEM connection
- 9428 miles: Installed AC EP158 Lift pump and Stanadyne FM100 30 micron pre-filter
OEM and Stanadyne filters have been changed at 10kmi. Mega filters were changed at 31,232 & 71,671 miles (currently at 82K).
Used filters are routinely cut open for inspection. Both Megas looked good with no visible discoloration. The Stanadyne will always have some black (asphaltene) discoloration but the OEM filters are relatively clear. The OEM’s are also fully uniform in color with no darkening on the bottom half (lift pump keeps the filter completely full - with stock suction system the filter is only partially full – see see Filter Council TSB )
4. History of injector replacement, if any, and at what odometer reading(s)
Original Injectors
5. Overall satisfaction with additional filtration - return on investment commentary.
I'm happy with my setup. Based on the Southwest Research institute’s “High-Pressure Injection Fuel System Wear Study” (SAE doc 980869) I think added filtration for our HPCR injection system is good insurance against wear related injector failures (i.e. ball seat erosion) and should help extend IP life too. Quote from the paper:
“The Southwest Research Institute (SwRI) Fuel Filtration Cooperative Research Program evaluated the effects of abrasive fuel contamination in rotary injection pumps to establish a baseline for high-pressure injection systems. It was determined that the critical particle size for rotary injection fuel pump was 6 to 7 microns.”
From my simple way of thinking the more filtration the higher the efficiency of removing the critical wear particles. However I’m not sure it does much to prevent design related failures (cracked injector body).
Here's a related and very interesting article in MaxxTorque magazine:
THE Black, White and Greys of the Duramax Fuel Filter
For me it’s so-far-so-good at 82K on an 03 with about 1 year to go on the 7yr/200kmile injector special policy. Unless I have a problem before it expires, for peace of mind I’m thinking I’ll take the truck in and pay to have return rate test done. If the injectors fail out of warranty I’ll probably just change them out myself. It’s still cheaper than buying a new truck.
