Results 1 to 20 of 30
Thread: Additional fuel filtration / injector replacement poll
    2009 1-ton extended cab.
    Don't plan on doing anything except add lubricity agent to the fuel and regular OEM filter changes.
    I fuel from my bulk tank, and logic dictates that if I were put a high-efficiency filter anywhere... it would be at the pump. At least that's my thinking.
    2009 GMC SLT 3500 Xtended Cab 6.6L
    Lubricated By Rotella T-6 and Amsoil EAO52 Filter
    Jan 2008
    Valrico, FL(TAMPA)
    The Suburban:
    Changed injectors, presumably because it had been sitting for a while in our DRY weather. Engine has a little less than 100K by what I can tell from dealer info & extrapolating the tag info before it was wrecked.
    Stock filter(DELCO only),& I added an old Raccor 500 10 micron (I think)like we used on the 5.7L & 6.2L(BOY, that was FUN!!!) I don't have the room that the later ones have. Nothing in it after 5K. It's before the main filter. I try to buy fuel where I think they will have a high turnover.
    Gordon Marks
    Tampa, FL (Valrico, FL actually)
    99 Suburban C2500 W/LB7
    55 Series 1 3600
    33 Chevy 4dr street Rod
    64 Biscayne 409 NSS
    "10.81@124.65"]10.81@124.65 3920lbs.
    gordon@marksair.com
    Jan 2003
    maui, hawaii
    See below for filtration installed (installed within 10,000 miles of new in both cases). I just had someone check my injectors with a TECH 2 on the 03 since the 7 year warranty is expiring. The check showed that the injectors (return rate, etc.) are right on the money.
    1) '03 GMC 2500HD Dmax/Ali Ext/Short 4x4; 4" exhaust, egt and boost gauges; exhaust brake; Bilsteins; BD exhaust manifold; Oil Guard bypass; Lubrication pre oem fuel filter; Tekonsha Prodigy; Mag-Hytec differential cover; Suncoast V transmission w/deep oil sump
    2) '07 Classic GMC 2500HD Dmax/Ali Ext/Short 4x4'; Bilsteins, Silastic shackles, BD exhaust manifold; Oil Guard bypass; Lubrication pre oem fuel filter; Tekonsha Prodigy; Federico sway bars; Dipricol boost and egt gauges; Transgo Jr,, Mag-Hytec differential and transmission pan
    Loyal WI US
    Quote Originally Posted by WyoDutch View Post
    Good logic indeed. Add a good dessicant breather/filter on the vent also. 99% of my fuel comes from my storage tank these days. If I make a long trip I add my 90 gallon aux tank which usually gets me home.
    FPPF Total Power in all fuel run through this tank. I buy Amoco Premier straight #2 non winterized whenever possible. I usually end up with a load of #2 winterized each year, but if I can I buy straight up and treat myself.
    Jan 2010
    GREELEY COLORADO
    Hey bigchev what kind of turbo do you run and what brand of tranny do you have?
