You'll want to change the TV cable itself too. The gasser cables will snap right in and look right, but it won't function properly, because the cables are different lengths from where they attach to the bracket and to the IP/Throttle Body. I had to modify the gasser cable I used because it was too long. After attaching it the bracket, it was too long to where it attached to the rod going to the injection pump, and by the time the IP was at full "throttle", the cable was just starting to move in the tranny, even with the cable adjusted as far back as it would go.
