Results 1 to 20 of 37
Thread: Anyone here ever changed out front brake hoses?
    Sep 2008
    Texas
    Exclamation Anyone here ever changed out front brake hoses?
    I got a '88 Suburban and trying to change the driver side brake hose out.
    I have run into a major problem getting this thing off. The tiny bolt attached to the brake line on the inside of the frame.
    I have tried all kinds of tools and cannot get none of them to grab on to it so I can break the fitting loose.
    I have tried wrenches (SAE/Metric), Channel locks, locking pliers, adjustable, pliers.
    Beside suing GM into bankruptcy for making such a crappy design, I am out of ideas.
    Thanks.
    Trent
    That fitting you are trying to remove is probably a rivet. Have you tried to remove the hose at the bulkhead fitting, where it attaches to the bracket?
    Sep 2008
    Texas
    There are no rivets.
    The brake hose fitting goes through the frame from the outside. On the inside is the brake line going to the fitting. It has a small bolt/nut which has outside threads. It threads to the inside of the brake hose fitting which completes the connection.
    However, there seems to be another nut against the frame on the inside. When trying to turn the fitting, the brake hose starts turning, hence for my need to get a tool that will fit it.
    That's the bulkhead fitting (your first post sounded like you were trying to remove a bracket, which some models have instead of going through the frame). One "nut" is attached to the hose (turns with the hose), and the other side is a threaded fitting with a jam nut. The nut that turns with the hose is only for holding it stationary while you loosen the fitting on the other side. Once the fitting is removed, the jam nut will release the hose from the hole in the frame/bracket.
    Don't blame GM for this one. It is a standard bulkhead fitting, used world wide in automotive and aircraft applications for decades. It is much easier to remove/install these, and others, with tubing wrenches. But, once you bugger it up with pliers, you'll have to continue with pliers. You may be better off to cut/chisel it off, at the hose side, which you are replacing, anyway.
    Sep 2008
    Texas
    I went out and got a pair of smaller locking pliers that have a better gripping mouth. It is on the bolt now snugly, but I am having trouble getting the fitting off. It is a bit stripped now. I can get a good grip on it with a small pipe wrench, but no room to move.
    I could probably go out and get that Sears too kit to remove stripped bolts & nuts.
    So what you are saying about the jamming nut is that you only need to turn it a bit and will lock the whole assemble into place?
    About cutting it off, I suppose I could do that with a reciprocating saw, but I am worried about not getting it out. The thread I have is threaded and If I can't screw it out after that, then I am for sure more screwed.
    Quote Originally Posted by trentc View Post
    Yes (to the bold part). The jam nut locks the fitting to the frame (AKA: bulkhead), against the fitting/nut on the other side.
    Is there any way you can post a pic of what you are working on? I want to be sure we are talking about the same thing. What you describe doesn't sound exactly right.
    Anyway, once the hose fitting is cut/broken off of one side (against the frame), the fitting will fall out the other side (maybe with a little help). You could use a saw, but it should chisel out just as easy. They pop right off with an air hammer (chisel bit).
    Sep 2008
    Texas
    Okay, here are a couple of pictures.
    As you can see, there are threads on the outer area.
    OK. That big stamped nut is the jam nut. The smaller thread inside the larger thread is the hose fitting. You need to place a wrench on the OTHER side of the frame to secure the fitting, while you loosen the hose fitting. If you try to use a plier on the larger threaded part, it will clamp the smaller fitting thread (and prevent it from loosening). The jam nut only secures the fitting assy to the frame. DO NOT cut the fitting, like I said before. If you do, you'll have to replace both lines. Soak the fitting with some PB Blaster and wait a day or two. It looks like some significant corrosion is at work, which will hinder your efforts. At any rate, the hose (smaller hex) is connected at the fitting in the pic, not the other side. This is not a bolt, but a threaded tube. Ideally, it should come right off, but they rarely do after 20 years.
    Sep 2008
    Texas
    Can you recommend what tool to use to turn that smaller threaded tube nut? I really do not want to be stripping it.
    Now if your up to some delicate surgery you can use a die grinder with a small cutoff wheel and carefully grind down the material over the actual hard line fitting where it enters the hose assembly.
    The secret is not to get crazy here. Worry the fitting down in 2 places on opposite sides so that it is very close to the inner threads. This will weaken the hold on the line fitting.
    Use only a tube wrench on the small fitting on the line, else you risk rounding it off.
    Once the brake line is clear of the hose assembly carefully move the line to gain some access to the other unit in the frame (Cover the fitting to keep the line clean)
    Now you can cut the stamped nut loose and the remove the hose from the hole in the frame.
    I have had to do this a couple times in the past. It will take a bit of time but the only thing you loose is the part you want to remove anyway.
    A air die grinder is great but a small Dremel will work fine too.
    Definately soak the fitting with the Skunk Piss.
    Be careful though once you start thing coming loose to NOT allow any of the penetrant to enter the brake line.
    Any contamination of the system with this high power solvent can cause issues with the brake calipers internal seals.
    Let us know how it goes.
    Best
    Robyn
    Sep 2008
    Texas
    I would prefer not to start cutting into this area because the area has so little space to work in and can only get one hand in the area. Once you start working in that area, your site of the area is obscured.
    Also, the use of "tube wrench" seems to be a generic label
    http://www.google.com/products?q=tub...num=1&ct=title
    There are numerous devices shown on that link labeled as tube wrench,and none seem to be able to remove that nut.
    Thanks for the help.
    Hi
    Try the term line wrench.
    They look like a box end,with a slot cut thru the box end so the metal brake line will slip thru.Some times the small fitting on the brake line will be siezed to the metal line so be carefull when starting to turn the small fitting.If it is siezed you will have to get the bulkhead fitting loose from the frame,then you can turn the old rubber hose assembly instead of the small metal fitting.After you have the old rubber hose assembly off then you can ussally work the small fitting loose from the metal line,you have to be very carefull you dont twist the metel line .
    If you can't get a line wrench and you still cant get the small fitting loose,then you can still get er done by getting the bulkhead fitting loose,using a wrench or visegrips if the small nut is getting striped hold the small fitting while turning the large fitting.
    You should be able to break the jamb nut off the bulkhead fitting,they are usally stamped tin and will brake off easyly,then you should have enough play in the line to pull it thru the frame and work on it where you can see it.A big screwdriver or small prybar driven between the frame and jamb nut will usally get it loose or break it.I usally end up doing it this way ,mainly to get the small fitting and line out where you can see it and make sure you don't twist off the metal line.
    Hope this helps
    Thomas
    Sep 2008
    Texas
    That term worked better. I see they are widely available. Do you (or anyone else) know what GM used for this nut, if SAE or Metric? Maybe even what size?
    It's for a '88 Suburban.
    Thanks for the help
    Craftsman has several options for tube/flare nut wrenches. You can get either combination type or crows foot wrenches, depending on the space you have to work with. Other brands and parts stores offer the same type of wrenches, as well. Your 1988 should be SAE, but verify the size with a standard wrench first. Like Robyn said, you can cut off the hose end sleeve and then get a 6 point socket on the nut. Still, your fittings need to be soaked with PB Blaster before you try to loosen them.
    Here's what the the flare nut wrenches look like.
    Sep 2008
    Texas
    I was aking about the size because I tried all of my SAE open ended wrenched and none of them fit. I also tried a metric set, and ditto.
    Though it is missing the size 9mm, so I am thinking that is it. I am just a bit tired of buying tools that are not helping me get the job done.
    Guess I will try a 9m tomorrow and find the PB Blaster and let you know..
    thanks
    I know. I keep echoing the PB Blaster. But, if you don't, you stand a good chance of twisting off the hose fitting. If it does, you'll have to replace the bulkhead fitting, and probably the hard line on the other side. Once you twist off the fitting, no tool will get it out before destroying everything else. PB Blaster is by no means a sure thing, but it improves your chances of salvaging the repair. If you don't use it, your chances of damaging the fittings is at least double. This isn't a sales pitch, but experience speaking. PB Blaster is a unique product, and I've found no other that will do what it does, as quickly. Soak it, and keep it soaked, for at least 4 hours, but 24 hours is best.
    Anyway, your wrench should fit it. I don't recall what size it is (been a long time since I've been under an 88, maybe a 9mm), but your standard wrench should fit. 1988 was a transition year (for GM trucks), and anything is possible, even if it isn't. Also check the new hose. It is possible corrosion has changed the size of the old fitting. At this point, I'd suggest cutting off the tubing sleeve on the fitting (on the old one!), and using a socket on it. Ideally, it needs to come out with as little hex-flat distortion possible. A flare nut wrench or socket will do this, and a socket is better. Remember, it's hollow, and probably very brittle at its age. Patience is a virtue, at this point.
    Sep 2008
    Texas
    I know for sure it is definetly metric because I have already cut the hose off and put on a SAE impact duty socket on it that "felt" as if it was correct size. I gave it a hard turn and stripped the fitting. I have the new hose and it measures to 15 mm. So I guess the other side is 9mm.
    I will go ahead and find PB blaster and apply it. Despite what the picture looks like, that area is actually all nice looking bright silver color with no corrosion. It's just got a lot of dirt on it. Seems the previous owners must have lived in a rural area due to the amount of dirt caked underneath.
    Well, off to find some wrenches..
    Add:
    Okay..got the PB Blaster from Wally World and applied. It will have at least 12 or more hours to soak.
    Sep 2008
    Texas
    Question
    I read a few other forums about people having some problems with the same thing I am having. They decided to go with putting on a locking pliers on the line nut & socket on the other side, and having successful results. They indicated even with the line wrench, it still felt like it was going to strip the nut.
    I have decided to go that route. I have the locking pliers on and a 16mm 3/8" socket on the hose side.
    I gave it a hard turn and it won't budge. Before I put on a 1/2" socket driver to give me more leverage to turn, I thought I would get some feedback from others who have done this.
    I am asking because I am really afraid to break the weak brake line nut and wonder if others have had to excert a great amount of force of getting it off.
    Thanks!
    Sep 2008
    Texas
    I went ahead and gave it a good turn. The brake hose nut is indeed rounded enough so that the socket did not grip it and slipped.
    Anyone got some ideas on a removal tool?
    Bummer. Your only option left, short of pliers, is a Craftsman "Bolt-Out". You'll have to cut away the crimp on the line so you can get the tool on. The tool is an inverse of an "EZ-Out", and they work. That, and more soaking with some PB Blaster. PM/email me if you are still scratching your head.
