Thread: Turbo Boost Bolt avalible now
    Burning Oil's Avatar
    Jul 2006
    Houston TX
    Default Turbo Boost Bolt avalible now
    Turbo Boost Bolt from www.pmdcable.com
    www.pmdcable.com
    Sweet and simple YEEEEEEEEEESSSSSSSSSSSSSSS
    Robyn
    Jul 2006
    Houston TX
    Thanks Robyn.
    I was thinking about giving a Turbo Boost Bolt away to a member here. The only condition is I would ask that member to post back on the forum a review of the item. Good or bad, pros and cons, pic's of the install ect.......
    Robyn, since you replied I will give you first shot. Interested?
    www.pmdcable.com
