Braking changes after 5MPH
Hello again,
Since I've had the Burb, the braking behavior has always changed when slowing down below 5 MPH.
Lets say I'm traveling at 40MPH, slowing down for a stop light. When speed decreases to 5 MPH, the bake pedal suddenly drops then feels notchy (hope that makes sense). Pushing down on the pedal (from 5 and below) seems to move in steps.
The vehicle always stops just fine. It just seems to be a strange behavior.
I assumed that the change was due to the RPMs on the power steering pump slowing. I installed a new pump (due to catistrophic failure, the shaft broke), and the brakes behave the same way.
Anyone else experience this? Do you think it indicates a failing booster?
Thanks.
Dave
Completely Fried. Toasted. Burned up.
New 3" down pipe and 4" exhaust new in box.
'99 Suburban 1500. 8 Lug Wheels.
Code F (As in Fried) Engine.
4 Speed Automatic Heavy Duty Transmission.
3.42 rear axle ratio
Heavy Duty Trailering Equipment.
Heavy Duty Auxiliary Transmission Cooling System. 8,050 GVW Rating.
New Power Steering Pump.
New Alternator.
New Wastegate Vacuum Soleniod.
New Front Blower Motor.
Plugged rear A/C Lines. Now leaking again. No A/C.
Newer Fuel Injection Pump.
Newer PMD with Heat Sink.
177,000 + Miles.
