Fuel Pump
Well I got my truck in to find out whats causing the leak. It turns out that the high pressure fuel pump was starting to fail and blew out the plug (kinda like a freeze plug) in the bottom of the pump. The mechanic found some metal shavings in the valley of the engine and if you look in the the hole on the pump you can see something is not normal in there. Soooooo, $1050 for the pump, $1200-$1300 for labor and $150 for gaskets I will get my truck back on the road. I only hope that none of the shavings I saw got to any of the injectors.
Anybody else ever had to replace this pump? For what reason.
2001 GMC Sierra 2500HD 4x4
Duramax w/Allison Tranny
Pacbrake Exaust Brake
