Unless its a 506 AMG block, thats the one to have. Look for two diamonds under the intake cast in the center of the valley of the block, also 506 will be cast in dots on each side of the valley. The 506 is the best or worst block, just depends who built it.
The turbo HMMWV's use van heads, so you really dont want one of them unless swapping heads. Plus most turbo engines were in armored HMMWV's, they were worked alot harder(about twice the weight).
