Results 1 to 2 of 2
Thread: FREIGHTLINER M2 coolant antifreeze problem
    Default FREIGHTLINER M2 coolant antifreeze problem
    Hello
    I i have 2005 M2 with MBE 900 120,000 Miles coolant antifreeze smell started a few days ago in cab and few days late low on coolant engine will shut down giving me engine protection i Will fill up coolant and can keep on driving fine did not over heat replace the EGR cooler a year ago and three months ago the EGR valve please help
    Thank you
    Not sure if we'll be much help here - these forums are for GM diesels. Aside from the obvious "is it leaking coolant somewhere" or "is there white smoke at the exhaust" we won't be much help on this particular engine.
    Try searching with Google on the engine make/model to find other discussion boards...
